NDX2 variable volume control
Hello,
I am using Roon on the NAIM NDX2. When I change volume control on the NDX2 from fixed to variable I can control the volume via the NAIM app, but on Roon it keeps saying ‘fixed’. How can I also control volume via Roon?
Thanks for your guidance on this @support.
Best,
Pieter
Hello @Pieter_Bult,
Try fully power cycling the device (ie. remove the power cord) after you have set it to Variable Volume in the Naim app.
Power cycling the device allowed our in-house NDX 2 to appear in Roon as variable volume. We will forward this report to Naim to see if we can improve the behavior here.
-John
Hi John,
This worked!
Thanks and best,
Pieter
