I was using smb shares couple days ago which works smoothly, but today roon tells i can’t connect to the smb share. and when i tried to add this share, it keeping tells me unexpected errors.
I am running the latest roon rock, the nas system i am using now is truenas scale 25.04.
I’ve tried to load the smb share on my windows pc, it just works fine.
tried to reboot nas, reboot roon rock, reboot smb share service, but seems nothing really helps. is there anything else that i can do to make it work again?
Last I saw a similar thread the reason for unexpected error was because the share was already mounted and one simply can’t mount the same share a second time. See the list of available locations on the left side.
If that is not your case, feel free to post screenshots. If you want Roon Labs support then:
