Do you need help with one of our products? Well, you’re in the right place!
Just click on the “Get Help” button at the top of the Support category, or click the image below…
From there you simply need to answer a few questions and will then be able to enter a description of your issue.
If required, a community post will be created on your behalf and a member of our team will be with you shortly in order to provide assistance.
In the mean time a member of our user community may be able to lend a helping hand and get you back up and running even faster.
Frequently Asked Questions
The Roon Labs Help Center is a great place to find answers to common questions or issues.
Here are a few places to start:
