sorry, i lost your answer. now it’s been a long time. in that time, I then formatted everything and decided to halve the music library. then still other changes, now I have problems with the new Melco S100 Switch, I lose packets and ROON returns network errors, but only if I connect the Melco S100 with the slowest ports (the first 4 ports) to the DCS bridge. if I use the other 1Gbit ports everything goes smoothly
Hello @Giona_Orlandi ,
What does your full network setup look like?
If this works as expected, can you continue to use the 1GB ports?
many thanks Noris for the replay,
I can use the 1GB one, but the 100M ports are better in sound quality (at least that’s what Melco’s say).
it is a problem that can depend on various factors, my configuration starts from a windows 10 20H2 PC with latest version ROON core via optical fiber in a Qnap switch then with copper in a Melco S100 switch then in the dCS Bridge and finally in the dac
I use the 1 GB port for the roon core (ROCK) and the NAS.
The streaming clint is connected to the 100 MB port.
This has worked without errors since day one.
btw: the internet router is also connected to the gigabit port
Rüdiger
which kind of streaming client ?
The client is also a “little” NUC. The operating system is Win Server 2019, core mode & RAAT.
USB → Audiobyte HydraZ → I2S → ROCKNA Wavedream SE .
Rüdiger
If I am not mistaken Roon doesn’t support Server 2019 ?
To be very clear:
My roon core is a NUC with the BS ROCK.
It “fetches” the music from a NAS and streams it (via RAAT) to a 2nd NUC. The client. And here is the OS win Server 2019. (core mode, without graphical user interface).
interesting solution! try as I am doing to interpose some audiophile switches, it should improve the sound quality a lot
