Ubuntu 20.04.3 LTS, Intel NUC 6i5SYH. 8GB RAM, Intel Core i5-6260U CPU @ 1.80GHz
Roon 1.8 (884)
All on ethernet LAN. ZTE GPON bridge of ISP->Mikrotik RB2011iL main router doing NAT/PPPoE/firewall->unmanaged TPLINK LS105G 5 port gigabit switch (for NUC and Dell laptop).
RB2011 also connects KEF LS50W, smart TV and wifi AP via ethernet.
NUC->Topping D70s DAC USB input from NUC->Topping A90.
51 albums, I dont know how many tracks. Plus TIDAL HIFI subscription.
When I play some MQA tracks from Tidal while DSP is active (headroom management and/or Parametric EQ) the sound occasionaly stops during play or is not present from start of the song. I noticed it happens when new track starts to play or I pause/play the song. The new track could even be the same track which currently plays and set to repeat. When it starts over, there is no sound.
It happens even when I browse different albums and play random songs.
Same trouble is when I sometimes try turning off an on the Parametriq EQ or vice versa. Or sound appears after some time when the songs is already playing.
MQA 44,1kHz is OK:
MQA 96kHz → no sound, or sound only in left channel, or right channel, start/stop doesn’t help:
It looks like a problem with MQA core decoder when enabled. When I disable it and DSP in enabled everything is OK. But i guess I am not listening to MQA anymore. DAC is signalling PCM:
When I disable DSP and MQA core decoder is disabled too, no problems with sound, but I have no equalizer:
DAC shows MQA 96kHz:
