Gigabyte Ethernet
Holo Spring (USB) and Aries Mini (Gigabyte Ethernet)
After I’ve updated my Roon Remote on my Android phone to build 528, I encountered not able to connect to Roon core, most of the time. If it does connect it will always connect to ‘settings’ page as compared to my iPad in the ‘Overview’ page. This is very strange indeed. I don’t have issue In the previous build 521 in my phone. I’m running on Android One OS Pie 9.0. The hardware are
Qualcomm MSM8953 Snapdragon 625, Octa-core 2.0 GHz Cortex-A53
Adreno 506 with 4GB of RAM. It is a Xiaomi A2 lite phone.
Note that if I can manage to connect after several try, it doesn’t go to the main page rather always in the ‘settings’. This is first time I encountered this in build 528. Can you guys check?
Hi @noris
I’ve tried to re-installed Roon remote several times on my Android phone but still unable to connect to the Roon core. Now I use primarily my iPad to connect or my laptop to connect Roon core.
I’m using a main router that is connected to Roon core for all Roon remotes.
After updating to build 528 on my android phone, it works for the first time when I launched the app. After closing the app, and launch again it no longer connect to the Roon core. The previous version works. I’m using a Xiaomi A2 Lite running on Android One OS, 9.0 pie. The hardware specs:
