I am having a problem getting my NUC with Roon Core to recognise a 512GB USB flash drive. The drive can be detected no problem on a mac book and a windows PC. The NUC does detect, and can play back music files via Roon from a Portable 4TB USB HDD that I have, so I know it works in that scenario but for some reason cannot do the same with the USB Flash drive. I have run a chdsk on the flash drive as suggested above, and can see that it is formatted as exFAT so all good on that score. Have also tried putting the flash drive on all three available USB ports on the NUC. Anybody got any suggestions?
Having said that - I did have one flash drive a few years back that refused to be read on a ROCK/NUC, but was happy with a Windows PC, so it can happen. Don’t know what the root cause is though.
Ben with support here, thanks for your patience while we work through each thread.
Are you still running into issues getting your core to recognize your thumb drive? What do the shared settings on the drive look like?
If possible, can you please reproduce the issue and try to connect it, and take note of the specific date and time? Share that info here, and we’ll be able to enable diagnostics to take a closer look.
When I have entered the thumb drive into the USB slot on the NUC I try to “Add folder” from the Storage setting and no drive is detected. I entered the thumb drive into each of the three drives between approx 16:11 and 16:13 (UK time) on 9th March.
I’m a bit unclear about what you mean by asking about shared settings on the drive - can you expand on that?
Thanks for reply Geoff. I selected “Add folder”, and I then get a screen returned the same as your screenshot. However I have no drive to select in the left hand pane.
No, I don’t have another thumb drive. The thumb drive does work in both my Macbook and Windows PC so I know the drive is not damaged.
The NUC does recognise a Portable 4TB USB HDD that I have, so like you say it’s strange.
Your NUC does recognize a Portable 4TB USB Hard Drive which validates that the NUC’s USB is working correctly and therefore the issue is with the Thumb Drive.
Since you only have this 1 drive.
USB Thumb Drives can be had for $10. You can just purchase another USB Drive.
or
You could copy the USB Thumb Drive to the computer for a backup. Then reformat the thumb drive and then copy your library back to the USB Thumb Drive.
NOTE: Before formatting this Thumb Drive, make sure you have a copy or 2 on your computer. Also validate your copy has transferred successfully. Then when you are absolutely sure you have a working copy, then re-format Thumb Drive.
I would opt for a purchase of a NEW USB Thumb Drive. USB Thumb Drives are not very reliable to begin with.
So there’s good news , and not so good news. Forked out £20 for a thumb drive from Amazon with decent reviews. I have just under 500GB worth of tunes, so thought I’d test it out and copy a few albums worth of tunes onto the thumb drive and check that the NUC can see the drive and the tunes. That worked, so happy days.
The not so good news, the copy of the 500GB’s worth of files has been going for approx 6 hours and is only 14% completed. Sometimes when I check on the progress it seems to have stalled, other times it’s literally only doing a few KB/s - the best I’ve seen it do is about 13 MB/s.
The other thumb drive that I have that is not recognised by the NUC takes about 4 hours to copy the 500GB worth of files. Such is life!!
It is more than likely a USB 3.0 thumb drive. However most computers older than a year still have a USB 2.0 along with a USB 3.0. They are backward compatible with each other especially for minor stuff.
However for projects as this, you need to make sure to use the 3.0 port. Normally designated by a Blue feature connector on the PC. Hugh difference in transfer rates.
It’s a USB 3.0 port that is being used to copy the files.
And to answer Rugby, yes my core is a ROCK NUC, the music is being copied from a folder containing music on the C Drive of my PC to a thumb drive on the the same PC.
So, as stated earlier, it was confirmed that the USB port on the NUC was still operational and therefore it probally was the Thumb Drive even though it worked on your PC and as it turns out it was the Thumb Drive.
