Does anyone have an issue with very short power outages and their nucleus?
I might be experiencing an issue with a very slight (generator does not even go on) power outage and my Nucleus shutting down for several minutes, even though nothing else on my circuit goes down.
@support@noris@jamie@danny So it looks like there may be some power management issue with my Nucleus. If i have my AVR and my Nucleus on the same power strip and very quickly turn the power off, my AVR boots up within 10 seconds, while the Nucleus needs 5-10 min to power up. Is this normal behavior?
Also, from what I witness on this forum, Nucleus models don’t handle power interruptions very well. It seems that power interruptions have the potential to irretrievably damage the M.2 drive, not to mention the possible corruption of the database.
So it looks like there might be some power issue. If I disconnect the power supply for a second,and reconnect it the nucleus takes about 5 minutes to reboot.
To reboot, or for the Roon Core to start servicing Roon Remotes and Roon Clients?
A reboot should only take a few seconds, and then the Web Administration page should show up. The time for the Core to be up and fully running is dependent on the size of the library. How many tracks do you have in your library?
I’ve activated diagnostics for your account and I do notice RoonServer abruptly ends at times, even while music is playing. I would strongly suggest adding an APC to your setup as soon as possible.
Power outages can negatively impact the Roon database stability and SSD health. I am not seeing any SSD errors at the moment, but continued power outages may cause further instability.
You may also want to try an Operating System Reinstall from the Web UI in case there are any issues with the operating system after the power surges.
