Continuing the discussion from Need advice please with HEGEL:
Suddenly, my Nucleus server disconnected. I can see it on the network, it has an IP address, I can remotely shutdown and reinstall the OS but it doesn’t connect. It stays on “loggin in” for minutes and stops process after a while. The ethernet port is blinking fast, maybe a problem there. Any suggestion ? Thanks,
Luc
Hi @Luc_J_Meeus,
It doesn’t look like the images you tried to upload came through. Can you try adding them again?
Can you give some details on your network setup?
If possible, can you try setting the DNS option on your router to Google DNS or Cloudflare DNS?
