Nucleus One Linear Power Supply Recommendation Request (ref#USQ28U)
I just ordered a Nucleus One and I am looking to upgrade the linear power supply. Do you have a specific manufacturer and model that you recommend? Thanks, Todd
AT&T modem/router - Small Green Computer LPS - Melco S100/1 switch - fiber from modem to switch
Hi @todd_mcdade,
Thanks for your inquiry! Officially, Roon only recommends using the power supply that ships with the unit. If you’d like to reach out to users directly with this request, we can move this to the Tinkering category.
