Roon nucleus
Core is connected to Verizon latest router, no model number is listed
Audio device is chord Dave
No tracks in library
Roon won’t see audio device
mjw
February 14, 2023, 2:20pm
2
Welcome to the Roon community, @Salvatore_Rosselli .
Please provide sufficient detail to help diagnose the problem. For example, how is the Chord Dave connected to your core?
Chord Dave is connected via USB.
mjw
February 14, 2023, 9:47pm
7
Do you have any devices listed under Roon Settings > Audio?
No nothing shows up. I’ve tried replacing the USB cable and the DAC itself but I get the “no audio devices found.”
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
February 14, 2023, 11:58pm
9
Silly question, I assume the Dave is powered on?
Roon can only see a dac if it is on.
And the signal then goes where after the Dave?
mjw
February 15, 2023, 8:43am
10
Are any devices listed? Not just the Dave. A screenshot would be helpful.
Yes the Dave was powered on.
mjw
February 15, 2023, 10:13pm
13
Click on Manage audio devices , and share a screenshot of Settings > Audio .
Use this guide to post a screenshot.
mjw
February 16, 2023, 9:18am
15
Thanks for posting the image, @Salvatore_Rosselli .
I’m flagging @support who can check the logs on your Nucleus. It is possible that the SSD is faulty and has corrupted the database.
It’d he helpful if you confirmed when and where you purchased the Nucleus.
The nucleus was bought on November 11, 2020 at Audio Video Therapy LLC in Nashua NH.
Wes
(Wes)
February 16, 2023, 4:27pm
17
Hi @Salvatore_Rosselli ,
Are you seeing the same blank audio screen on your iPad and phone? What device are you using when you shared this screenshot?
Thanks,
Wes
I’m seeing a blank screen on both my IPhone and my IPad. I sent the screenshot from my IPad by way of my phone.
Wes
(Wes)
February 16, 2023, 10:21pm
20
Thank you for that confirmation.
Let’s do a RAAT refresh on your Nucleus. I see where this has fixed the issue for other users and I’m hoping for the same results with you.
Please be aware that this will reset your Roon Settings → Audio Tab to factory settings and I would advise making a backup of any custom DSP settings you have:
Create a Backup of your current Roon Database
Stop RoonServer from running in Nucleus’s WebUI
Navigate to your Roon’s Database Location
Find the folder that says “RAATServer”
Rename the “RAATServer” folder to “RAATServer_old”
Restart the RoonServer in the WebUI to generate a new RAATServer
Please let me know the outcome!
Wes
I have no idea how to do any of this. And I don’t understand some of the terms. Where’s the webUI? I’m sorry but I’m not very computer savvy.
mjw
February 18, 2023, 10:43pm
24
Salvatore_Rosselli:
Where’s the webUI?
The Web User Interface (WebUI) can be found by typing the following in your web browser address bar:
http://nucleus.local
This assumes you have a standard Nucleus. If it’s the Nucleus Plus, type…
http://nucleusplus.local
I tried backing up roon and it won’t. I get a message “backup failed”. Can I proceed with the rest or would that be disastrous? Thank you for your all your help thus far.
mjw
February 19, 2023, 10:07pm
26
If you don’t have a backup, and the additional steps go awry, you’ll lose your play history, DSP settings, library edits etc., and will have to start afresh with a new library.
