1 in 4 ish startups. Plays for between 30 secs and 3 minutes and then just stops.
No change in the GUI.
Quit and relaunch fixes it.
Is it possible to roll back (and then never update again)?.
Update: it can go 30 mins. before it stops.
Specifically what else to you need?
Front end surely irrelevant at it happens whether using phone or desktop.
Core on Nucleus
Usually streaming TIDAL not sure if it happens with local data.
Plusnet router
TPLink switch
Meridian 218 zone controller into Meridian G68 into Meridian 8000s
NEVER happened before the update.
Clue
The last time it happened I was playing music locally saved on a Melco M1 and I noticed the swirly icon in the top right and it said was scanning and adding tracks to my library.
Just another user here, having to blow your bubble, Iām afraid.
You could of course download and keep the current versions yourself, but Roon doesnāt keep old versions available.
Since Roonās functionalities rely heavily on online servers whoās code constantly evolves, keeping old versions will eventually break your system and no one will be there to help you out.
You could still revert to 1.8 legacy (search for instructions on the forum) but it canāt be started with a current version database backup, doesnāt get any further development and may also become non-functional at a certain point in the future.
As a tip, try to keep your set-up straight and simple, so better attach a USB disk with your music to your nucleus instead since it reduces complexity and additional network traffic from and to it.
Bill: Sorry, yes itās ethernet not USB. Logically (and I have a degree in Theoretical Physics) it seemed to me that a solid state device should out-perform something which has to move, but Iām inclined to trust my dealer. Can you point me at some data that might convince me otherwise.
Marin: Your last paragraph āAs a tipā¦ā Are you saying do this instead of the Melco? Do you think it would improve music quality? (I can imagine it would be more reliable). I like simplicity - I liked it when I had a CD player straight into Meridian DSPs via a passive volume control!
Again, nothing to do with sound quality, but reliability of data transfer.
You are having problems with that and thatās what I was trying to tackle.
EDIT:
Yes, I meant instead of the Melco.
A USB āStickā - aka a USB Flash Drive is indeed a solid state device, but itās not the same technology as a Solid State Drive, which is what is being suggested here.
With a Nucleus it is possible to store local music either on an internal 2.5" SSD (capacities of up to 8TB, and shortly 16TB are available), or on a USB SSD attached to the Nucleus.
Your Melco N1 also has an SSD fitted in it, apparently it is a āspecially-selected SSDā according to the product page.
Getting back to the issue at hand, if the playback ceasing happens with both Tidal and locally-stored albums, then this could be a network-related issue. Does the same issue occur when you play to a Zone set up on your Windows 10 PC, or is it only when you use the Meridian Zone?
You completely misunderstand me. Iām not arguing - Iām trying to understand. My request for data is precisely to avoid believing anecdote.
Bill_Janssen
(Wigwam wool socks now on asymmetrical isolation feet!)
21
Ah, Iām afraid I took your āplugs in the same holeā all too literally, considering the differences between USB-A, USB-B, and RJ45 sockets and plugs! I was confused.
As to rotating versus solid-state, I generally agree, but as @Marin_Weigel says, at this point in the audio chain, itās just data, and any appliance which can serve data reliably will do. A $170 4TB WD My Cloud Home would probably work as well.
When I see something that costs too much for its functionality, I always wonder whether, in the process of pursuing the price-no-object consumer, they may have neglected other salient design and manufacturing issues. The luxury market in general suffers from a surfeit of marketing and a paucity of quality assurance testing.
