Windowa 10 PC
ASUS AX 5400 RT-AX82U
Pro-Ject Streamer Box Ultra
Library Size
70.000
Hello
I just upgraded my system with a Pro-Ject Streamer Box Ultra.
Chose it because it was ROON ready.
Has started a trial subscription to ROON. I then thought to pay per year.
Now to my problem.
My new Streamer works perfectly and sounds magically good when I play via the Pro-Ject app
(connected to my DAC Primare NP30 via USB)
Have a powerful PC with ROON Core installed. Also it seems to work. I have scanned my music library about 70.000 songs. ROON shows and sorts EVERYTHING.
What a wonderful interface!
If I just make it work, I will never leave ROON.
From the ROON app, I see everything perfectly, even my Tidal playlists.
But I do not get any sound from the streamer via ROON.
Everything plays without problems via the ProJect app.
What did I miss?
Sees the Streamer (with IP 192.168.1.83) as an option when I click on the connection icon in ROON, but no sound from the streamer. When I switch to the ProJect app, everything works.
Is there any setting in ROON I missed?
Would be very happy if you can help me. Have searched online but not found any instructions on what to set on ROON
It would be extremely sad if I can not make this work now that I have found wonderful ROON. But as you understand, I will have to cancel my subscription if there is no solution.
Attach some screenshots of the settings that may be relevant
Please help
Sincerely
Lars Axelsson
Sweden
