I have a brand new Pro-Ject Stream Box S2 Ultra which is not performing as expected and looking to hear from others and share their experiences.
This is my current setup:
ROCK (Ethernet)
NUC7i7BNH
16GB RAM Crucial (2X8GB) DDR4-2400 SODIMM
Samsung 970 EVO 250GB - NVMe PCIe M.2 2280 SSD - RoonOS
Samsung 860 QVO 1TB 2.5 Inch SATA III Internal SSD - Internal Storage
Mac Mini Running Roon Bridge
Pro-Ject Pre Box S2 Digital connected to Mac Mini via USB (no separate power supply)
MacBook Pro is my Roon Remote
New setup:
The Stream Box has replaced the Mac Mini in my setup; it is connected to my network via Ethernet. My Pre Box S2 Digital is connected to Stream Box via USB (DAC) port.
The Stream Box set up process was done using Safari browser and is updated to the latest firmware; easy-peasy. Everything was working fine on the first day of using it. I also used the Pro-Ject Play app for iOS to stream TIDAL. All my music stored internally on my ROCK played fine including DSD files. TIDAL MQA tracks played well too. The Pre Box MQA lit up and showed correct resolution when playing MQA tracks; I confirmed this by looking at the Source/Path displayed in Roon.
On the second day, none of my DSD music files would play; sometimes I would just get silence, sometimes static. Also, the Pro-Ject Pre Box would not light up to indicate playing MQA files and the full resolution was not being displayed on the Pre Box either.
I’ve power-cycled everything; no issues with any other devices on my network; reset Stream Box to factory settings and applied firmware update again — everything I can think of. Nothing has worked. FYI, this is my 2nd Stream Box. The first one was already returned as defective; had the very same issues but it also kept disconnecting from my network frequently.
All indications point to the Stream Box because I can take it out of the chain and replace with the Mac mini and all in the world is right again.
This little box is aggravating me and I just want to give it a chance before giving up completely and returning for a refund.
Any others out there who have a similar setup or have had success with the Stream Box, please share your experiences and knowledge.
Thank You!
