Having trouble with the SoTM end point device. I hope I’m calling it the right thing. It has worked flawlessly in the past but now I cant get the Play arrow to function. it just doesnt want to play. Cant figure it out and confuded as to how to trouble shoot. The DAC works fine when connected directly to the computer. The Rendu renderer in the “Living Room” works as well.
System output are devices connected to your Core directly. So the Windows system audio for you, I guess. Like in my case with Roon running on my Macbook and a Core that’s a separate NUC:
Apologies for the slow response here. I activated diagnostics for your account and I noticed you have been playing music successfully to your UltraRendu zone. Is your SOtM zone attached to your UltraRendu zone? Is everything working properly and without issue now? Let us know if you need further assistance here, thanks!
“playing music successfully to your UltraRendu zone”
yes that is correct. no problem playing through the rendu.
“Is your SOtM zone attached to your UltraRendu zone?”
No… I dont think so. They are labeled differently and I chose between them.
Still cant get the SOtM to play. Not sure how to trouble shoot but i know the DAC and amp etc work fine when OI take the usb out of the SOtm and play it through my computer.
I see your SOtM appearing as an airplay zone in Roon, are you saying that playing to it via Roon airplay is not working? What happens if you try to Airplay to it from an iOS device, does that work?
