i have the same problem, and everithing seems ok .the only problem is with timeline on local albums…any help will do
thanks for your attention!
Hi,
The Roon @support team prefer one topic per customer’s issue… so they are able to track it and focus on each individual problem. hence I split out your topic.
In order for Roon’s @support team to better assist you, please provide a brief description of your current setup using this link as a guide.
Make sure to describe your network configuration/topology, including any networking hardware currently in use, so they can have a clear understanding of how your devices are communicating.
Hi again @jorge_antonoglou,
Just a thought, … has your music finished the initial audio analysis? The analysis is what builds the waveform for the local files.
Or it could be you switched it off in Roon’s settings, so worth double checking that …
Do you have the latest build of Roon installed? You should see build 571 for both Core and Remote under Roon Settings -> About.
