I have currently two problems with ROON. One is that I encounter the message ‘Fatal Error’ - when I start up Roon - after couple of attempts ROON does start up despite this message. I use an iMac with the latest software and ROON
Second problem. When I try to add a tidal album - the process always ‘takes longer than normal’ - if I then try again the message is: ‘This album has been deleted’. The result is that I cannot add tidal albums…qobus works without a hitch.
In order for Roon’s @support team to better assist you, please provide a brief description of your current setup using this link as a guide.
Make sure to describe your network configuration/topology, including any networking hardware currently in use, so they can have a clear understanding of how your devices are communicating.
I cannot add an album in TIDAL. If I try to add one I first get the message: ‘This album takes longer to add’ and then if I try again after some time: ‘This album has been deleted’. The result is that I cannot add tidal albums…qobus works without a hitch.
Second problem: When I open Roon on my computer - I encounter the message ‘Fatal Error’ - when I start up Roon - after couple of attempts ROON does start up despite this message. I use an iMac with the latest software and ROON
I have an B&W A7 wifi speaker - and I cannot seem to avoid drop-outs in sound. It is present most days wen we use the A7. I use apple WIFI with a router - Apple AirPort Extreme and an apple extension router.
My setup is the following:
iMac (2019, 3,6 GHz 8-core Intel Core i9), 64 GB 2667 MHz DDR4, Macintosh HD, Radeon Pro Vega 48 8 GB) - this is connected to a harddisk Format Mac OS - Journaled, 5 TB via USB and with a mytek 192 DSD DAC through firewire and a B&W A7 through WIFI. (WIFI Described above).
SOFTware: macOS Big Sur version 11.1 - Roon 1.7 (710).
Remotes latest versions on quite new iPhones and iPads.
Streaming services Qobus (works perfect) and Tidal
Can you reproduce this and let me know the time that you add the album and the name of the album? I’ll enable diagnostics on your account so our team can take a look at what’s occurring here.
Our team is currently investigating this issue — I’ll follow up soon when I have more information
As we note in our Networking Guide, we typically recommend against WiFi, and we also recommend against Apple networking gear. It’s not 100% certain what the issue is just yet, but as a test, are you able to connect the A7 via Ethernet instead of WiFi? Do you experience the same dropouts?
ON the first point: It applies to all Tidal albums. I cannot seem to add any of them. Do you want me to add an album say on 22.00 CET (in eight minutes) - I have the Batbxy album TheHxliday ready for the test.
On the second point: Happy to hear you are investigating it. Finally on the third point, I also suspect the Wifi gear and will move to Wifi 6 soon and hope this will solve the issue. I will try to test it wired up as you suggest
