I am having the same problem here. It happened with a Nucleus and a Nucleus+. I’m in a commercial building, and I wonder if the network here could be the problem? I can send details if anyone needs.
Hey @ciamara — Thanks for reaching out, and apologies for the difficulties here!
This behavior is typically caused by networking issues, so knowing your particular setup as well as having some more details about the issue will definitely help us identify what you’re experiencing. Please also verify the following so we can gain some greater insight:
- How often does this behavior occur? Is it constant, or just an occasional disconnect?
- When the remote device is in this state are you able to connect from another remote device?
- Does this behavior occur with all remotes? What kind of remotes have you tried?
