Everything works except I can’t play MP3 and certain other files. I can play FLAC, WAVE and some others. I get a message that I’m missing codecs.
Rock is running on the NUC. I copied TAR ffmpeg file into the Codec folder in the DATA Directory of ROCK running on the Nuc and rebooted. I did this many times. I still can’t play music files in certain codecs.
I’m running an Xfinity modem into a Netgear Switch. Nuc and main computer is ethernet. Endpoints (Rasperry Pi, Sonos, Mytek Bridge and some stuff playing with Chromecast/Airplay) are on WiFi.
There are various audio connection and DACs. DACs are Mytek, McIntosh, Schiit, Sonos, to name a few.
Please help. I would like to play my music in these lossy formats. Thanks.
Agreed the tar is stilled compressed its need to be unpacked with something like 7-zip.
I just realized that you said in the other thread that you uncompressed it.
Will need to get @support involved as there seems to be something weird going on.
You dont rename anything, the TAR file once unpacked properly will have a file named ffmpeg. This instruction is for QNAP but the process for unpacking the TAR file is the same.: -
Pardon if this comes accross as obvious but, just to be clear on how the process works:
The file you download is “ffmpeg-git-amd64-static.tar.xz” (which is a double compressed set of files and it takes two steps to open tar.gz files)
First: you unpack the *.tar.gz file and that gets you a directory “ffmpeg-git-amd64-static.tar” that contains the file “ffmpeg-git-amd64-static.tar” (another compressed file)
Second you unpack file “ffmpeg-git-amd64-static.tar” which gets you directory “ffmpeg-git-amd64-static” which contains directory “ffmpeg-git-20210425-amd64-static”
Directory “ffmpeg-git-20210425-amd64-static” contains two directories and five files, one of which is “ffmpeg” with no file extension.
As @Scotav says you should not be “renaming” anything to get the “ffmpeg”.
