My plan is to release it till Sunday evening.
Best DrCWO
Dr CWO a big thanks RooMax is excellent for controlling Roon - now one feature I would love is something that can send IR commands - and being able to send those IR commands using the Quick keys controller - one command for volume and one for input selection of my preamp
This is already on my long term worklist. So enough work for the winter ![]()
Best DrCWO
You can do this now with DeepHarmony and use rooMax to send the volume up/down commands. Better IR support directly from rooExtend would be a great addition @DrCWO thanks for putting this on the list.
I setup rooMax yesterday, using an old Pi3 for RooExtend. It works wonderfully and is just what I needed. Thanks, @DrCWO for making this a reality.
Thank you ![]()
If you need support on rooMax please notice that it has its own support thread.
Best DrCWO
I am facing an issue that I can assign playlists created in roon to selected buttons in the settings, but when I click these specific buttons nothing happens. The playlists what I created in tidal however works as intended.
Is this a known issue or I do something wrong?
There is an issue on the Roon API side that Smart Playlists are not yet supported by the Roon API. Is the playlist you like to use a smart one?
Thank you for the quick answer. Yes, smart ones.
So this is a known issue in the Roon API ![]()
I can’t help here. We have to wait until Roon fixes that. Sorry ![]()
Hello,
just want to know if the latest update (especially rooMax) for the rooextend box is online or if I have missed something.
rooMax is already available on the rooExtend-Box with v3.4.2. Please check in the rooExtend License Manager if you already have this release. You should. If not please post this from the and of your settings dialog in the License manager:
Only the latest improvement for the zone selection via the wheel is not yet rolled out for the rooExtend-Box.
Best DrCWO
Fixed that right now and it will be in the next release.
best DrCWO
Thanks DrCWO, much appreciated
@DrCWO is this option to go above a 100 playlists in RooMax still coming? It would be nice not bumping into that limitation🙂
Is on my list and will be part of the next release (still this year) ![]()
Best DrCWO
Thank you very much.
I’m really enjoying the new way of controlling that RooMax and QuickKeys brings. It’s sort in between an iPad and the Numio/Dial in quick and casual access to Roon. It easily covers the whole apartment and its four zones. You really made a great addition to Roon here:+1:![]()
Hi @DrCWO,
I’m finding rooMax to be very useful.
One thing that I think would be a useful addition to the functions of the rooMax Control Sets:
The way I have set up the Control Sets is to have Control Set 1 with my most frequently used functions (and I would imagine most people would set it up similarly). And then Control Set 2, 3 and 4 are used for less frequently used functions.
It would be very useful if the button that toggles the Control Sets could have the option of a Long Press to go directly back to Control Set 1.
Hi @DrCWO
Really love the functionality of Roomax and the QuickKeys controller.
A possible feature that I would like to use - quite often when listening to playlists - I come across albums and tracks that I would love to add to Roon or even mark as a “favourite” - would be a cool feature instead of needing to retrieve ones IPad or phone. Don’t know if this feature would be at all possible?
Is on my list for the next release now. Hope this can be achieved ![]()
Best DrCWO
