I tried rebooting and the problem remained, it wasn’t a spike. I am currently using Roon and for now the cpu is spiking at 58% though going up and down and is acting normally with no fan noise.
Thank you for that additional information, I have added this to our investigation. If we have any further follow-up questions, I will be sure to let you know. I appreciate your patience while this investigation is ongoing.
Mac Mini 2018 3.2GHz 6‑core 8th‑generation Intel Core i7
Mac OS Mojave 10.14.6
32Gb RAM 2666MHz DDR4
256GB SSD storage
Its consistent for hours no matter what you do in the app.
Yes it does
Ubiquity -
185Mbps DL via Comcast DOCSIS 3 connected to
Unifi Security Gateway In turn to
Unifi 16 port managed switch
1Gbps connections on wired Ethernet to the core and library
Library is on a 6 disk Netgear ReadyNAS with dual bonded 1Gbps to the Unifi switch
Juat checking back. the problem continues to persist. it’s a bit of a hassle to login to the NAS to restart Roon and it’s pretty temporary. For instance, it may only last 30 minutes and then the fans will start and the CPU usage will be >50%. Anyway, appreciate any efforts for a solution.
Thanks for the update. QA is currently investigating this behavior internally. I can’t comment on a timeline of when the investigation is complete, but we’re working on narrowing down what could cause this behavior.
I thought I had it licked. I had disabled Dropbox syncing and turned off Better Touch Tool (which had a Roon for the touch bar app). Roon worked for 3 days without hi fan usage. Then I closed down Roon and restarted it again after about 20 seconds. It went to over 300% CPU usage. I then stopped Roon again. So… 3 days with no problems after a reboot but then for no apparent reason it became a resource hog.
I dont see the exact same scenario as you guys, but i do notice a high power consumption of Roon on my MacBook Pro (2017 model, i5)
But, the fact that Roon pulls three full cores after startup shouldn’t be a surprise? It does need to rescan your libraries and recheck any cahnges in metadataproviders if something is discovered?
I normally don’t use my MBP as Roon Core though, only when i’m on the go, along with an external 4Tb drive and some InEars.
At Roon startup, it does pull a lot of power. After a few minutes, when libraries are rescanned and no music playing it demands some 30-40% of CPU resources. Of course this requires that all audio analysis has been finished. While that is being done all fans are on and power is drained at an alarming rate. (CPU usage as you describe, 200-350%)
When all is done and ready though, music playing and powering the external 2.5" music drive, the batteries still are drained pretty quickly, around three/four hours i’d say.
Edit: I seem to have a similar issue, as of right now, playing back a single stream, a 16/44.1 file from the external harddrive, to one endpoint. This should not need a full core. Still Roon consumes between 70% and 100% of CPU resources. (One full core, out of four.)
Library scanning was finished, both Qobuz and Tidl connected.
Edit2:
I left the Roon Core one the MBP playing and did some chores while playing music. after an hour, the CPU consumption was normal, around 10-12%… Weird!
This morning after running for a day Roon kicked up to 300% + and won’t get its self back in order, despite restarting the app multiple times. On this Mac it’s a remote and browser only, the core is on a Linux box so its not media scanning.
Restarting the whole Mac Mini solved the issue, at least on a temporary basis.
Mine is a control only and has been running smooth for a day and a half. It has not been stopped. I am watching carefully to see what may start it into high cpu. I really suspect a graphics issue as it is control only. I have a 2014 MBP as well with no issues. I think it has a different graphics chip though.
same issue here (300%roon / 100%RAATServer)
mac mini, specs in screenshot (remote)
core is rock on nuc
network: wired to gigabit switch (dlink 1024d) both core and remote
I’m having the same problem as everybody else. The fan spins like crazy, Roon maxes CPU usage and on the energy tab in Task Manager the text turns red.
Roon 1.7 (Build 528)
Mac Mini (2018)
64GM RAM 2667Mhz DDR4
MacOS 10.15.4
Intel i7 3.2Ghz 6-core
Intel UHD Graphics 630 1536MB
Internet via 10Gbe port
Music on local hard drive
Endpoints: Opportunity UDP-205 and PS Audio DirectStream DAC with Bride II (connected via CAT6a ethernet
Streaming Services: Tidal & Qobuz
Where are you in your process with Roon?
I mean, is your library already indexed, analysed and done with by Roon Core? Have you recently started the Roon application? Has it been running for a few days, while your lappy slept in between uses?
My company VPN seems to be the cause. Anytime I jump on the VPN for a work function, it’s Cisco AnyConnect, Roon will spin up to 300%. Every. Damn. Time. Reboot fixes. Tried quitting Roon before connecting to VPN and then restarting Roon after disconnecting, and it still goes gonzo. Only reboot resolves. I do have “Allow local (LAN) access when using VPN (if configured)” setting checked so I don’t drop my local NAS. Maybe I’ll uncheck that and see if it behaves differently next time I use the VPN.
Only a single test, but it seems that if I don’t have the “Allow local (LAN) access when using VPN (if configured)” setting checked when I get on my VPN, I don’t see the problem. It does take me a few tries to get my NAS remounted after killing the VPN, but once my NAS is connected and I relaunch Roon, it behaves normally and utilization is normal.
Has any progress been made on this issue. It had disappeared for awhile but with the latest update it sems to be back. Shutting it down and restarting is not helping at present. A reboot did help.
I never pay attention to the CPU usage, the thing that is driving me crazy is the GPU usage in my iMac, but look at this, CPU usage as well is high (Catalina +537, iMac 2019 core), it is around 300% Roon and RAAT around 90% high consistently I monitored it for about an hour:
@support I think we really need actions from QA in my case both GPU and CPU are an issue, so many issues in macOS.
Many threads reporting this as well. @Danny please a hand so QA help us with these issues.
Its been several months (6 or more) the users are reporting these issues and no updates from QA or communication with the users: Very high CPU load on MAC
I am having the same problem with my Roon on my MacBook Pro 15" 2019. This is crazy that there has been no solution from Roon in over 6 months. Roon, I see you have been able to reproduce the issue. I just cannot use Roon on my MacBook Pro with the Roon client overheating and fan on full. Close Roon, fan stops and temperature slows down. Roon, can you please put a senior tech on fixing this so that Apple users can use your product.
macOS Catalina v. 10.15.4
MacBook Pro (15", 2019)
2.4 GHz 8-Core Intel Core i9
32 GB 2400 MHz DDR4
Radon Pro Vega 20 4GB
