QNAP TVS-1282, FW 4.5.2.1566
AVM Fritz.Box 7590, Ethernet: 1 GB/s
ELAC Z3, WiFi
TIDAL and LIVE RADIO is not working. Playback for about 3 seconds. Then it stops with an error message:
dylan
(Dylan Caudill)
Split this topic
February 11, 2021, 6:49pm
2
dylan
(Dylan Caudill)
February 11, 2021, 6:53pm
3
Sorry for the trouble here, @Holger_Franke !
Is there any change if you reboot the Core machine?
Is local content playing okay for you?
Hi @dylan
unfortunately also locally stored music is not playing. I also restarted the NAS. Before updating to v1.8 it worked the past 3-4 years without any problem in the same setup …
@dylan … I observed playback on my iPad is working. Is the problem based on the speaker (Elac Z3) setup?
dylan
(Dylan Caudill)
February 12, 2021, 6:26pm
6
Thanks for confirming that this seems specific to the Elac, @Holger_Franke
Are you able to connect the Elac via Ethernet, even if just as a brief test? Is there any change when doing so?
Do you have any DSP enabled with the Elac?
I connected my KEF LS 50 and they work perfectly, @dylan
I have to figure out what to do to bring the ELAC Z3 up and running.
dylan
(Dylan Caudill)
February 26, 2021, 7:42pm
8
Thanks for the update, @Holger_Franke
Just to confirm, were you able to try connecting the Elac via Ethernet as a test?
Do you have any DSP enabled for the Elac?
Hi @dylan , after updating to the new build (764) both the KEF LS50 (wireless) and the ELAC Z3 work. For the Elac no DSP is (and was) activated.
system
(system)
Closed
February 27, 2022, 3:35pm
10
