Roon 1.8 Wasapi Audio Devices not auto reconnecting on clients
Core
Intel NUC I5 running Windows 10 and Roon Core 1.8 Build 756
Client
Roon Version 1.8 Build 756
Wifi and Ethernet
Schiit Audio Modi2 Uber - connected to the core
Sony USB DAC UDA-1 - connected to a client PC
When I first bring up the client the Sony shows as a viable audio option on the local client and on the core. If the sony shuts down, it still shows on the core but is not an option on the client. and the same with the SCHIIT audio WASAPI device connected to the core, if it shuts down and is restarted, it shows up on the core but not on any of the clients. The only fix for this is to restart the Roon core and then they will show up on the clients.
This worked perfectly prior to the 1.8 rollout.
This does not happen with any of the airplay clients
Thank You,
Mike
I think this also applies to ASIO, as I’m seeing it with both WASAPI and ASIO drivers.
My device is an RME ADI-2 DAC FS. My core is a linux system and client is windows 10.
my client is also windows 10
Same here, both on wasapi as on aiso. Windows 10 client. Linux Core is on NUC10i7. Device is NI komplete audio 6.
Hello,
Exact same issue that I am experiencing. A reboot of the Core temporarily fixes this until you restart the client. I’m also seeing no audio zones at times.
Basically a major cluster all around it would appear.
Thanks, Phil
Same here. I have installed, uninstalled, reinstalled, renamed and regenerated RAATServer folder, rebuilt my database, etc. many times. The Audio Zones are messed up. Getting really old spending this much time trying to get ROON to work. I just want this fixed!
Is this the wrong way to submit a support request?
Thanks,
Mike
Apologies for the trouble here, @Michael_Silva
Please see our update on this here
