Netgear Router R7000 - Everything is thernet wired (no wireless)
PC Audio card - Creative Z series
I just made a fresh intall Windows 10 and Roon and i’m starting to loose the settings for Audio device (here my PC).
Almost everyday I need to add my PC Audio device because Roon don’t keep the settings or something. So I need to go back in Settings - Audio and set back the PC Sound card then it play fine.
The next day samething I have no audio device for the PC and I need to do it again and I use WASAPI
audio device in the list. I don’t loose the core and also my NAD C658.
Only the PC Audio card is somehow get disconnect but I have no problem using it in Windows. Only Roon.
I reboot the PC but didn’t reboot the Router and the Core because everything is running fine.
Roon is just not keeping my setting for the PC sound card. Very strange never got this since I bought Roon last year,
I had a similar problem with the Sound Blaster Z and it’s Asio drivers. Did uninstall reinstall didn’t help much. Pulled it out used a Realtek Onboard sound card with realtek Asio drivers (didn’t realize until it showed up in Roon) and had no problems. At least nothing that the odd reboot wouldn’t fix. My Sound Blaster Z is up for sale…
I decided to use an old reciever a Pi4 and iFi iDSD Nano BL powered by an iFi iPower 5v instead. Still use computer audio for gaming and for music the iFi rig. (not my primary playback devices).
