Dear all
I know, I’m maybe annoying you with the display question.
But I really noticed that, in case you don’t have a Streamer with display built-in, it’s going to be hard to find something which: looks nice, can be used for forward and replay etc, and displays the artwort as it should be.
I’m asking myself why ROON is here not so supporting and make I don’t know an app or find a solution to get the best possible out of it. I’ve also noticed that most of you, gave up on this problem and accept how it is. Me not…sorry. I’ve paid a lifetime licence on ROON, which, to be honest is not easy money.
What I’ve tested so far, what worked and not, and if it worked, why not choosable (from my point of view).
Here what I have and tested:
GOOGLE Nest Hub 2nd Gen
- beautiful display
- perfect size
- need to activate screenreader
- red line / box around the cover art
- if no screenreader activated, screensaver starts and nothing visible
- no forward etc
Would be nice here, if GOOGLE would update and make it possible to set the screensaver to “do not start” screensaver (or something like that)
APPLE iPad
- beautiful display
- perfect size
- needs to work with Safari therefore no fullscren
- not cheap or you have an old iPad
- you need to buy a frame (on Etsy) or something like that
- no forward etc
Maybe here would it help if ROON creates an APP for iOS / Android (for Google Tablets) which is only based on showing artwork…
RaspberryPi Display with RooPiee XL
- display ok
- perfect size
- easy to use with forward etc
- updates
- display is not perfect (resolution)
- cases are not the best ones
Would be nice if the creator of RooPiee would give some informations about higher resolution displays etc.
NOT tested from my side:
Digital Photo Frame
+beautiful displays
+size can be choose
- need to find one with Android as OS
- if you install ROON (it will not work as display - maybe yes? cause of Chromecast)
I really think, that there is a huge potential regarding displays and what to show up.
Not all user have a large wall or a lot of space for adding a huge screen (like me - see my current setup )
I’m interested in your solutions and approach to this problem.
Many thanks and I hope, ROON will jump in and help us.
Best regards from Switzerland
Piero
