Roon Arc Port Forwarding and Remote Connection Issues
Roon build 1244 running on windows 10 laptop with Ryzen 5 CPU and 8GB RAM.
Huawei Router model Echolife HG8145V5, on Wifi connection.
Ifi Zen Dac USB Audio
14,000 tracks
I’ve tried to configure ARC port forwarding via UPnP automatic configuration and also manual port configuration as instructed in Roon’s troubleshooting page. However, after numerous refresh and reset I’m still not able to get a remote connection from devices to the Roon Core set up on my PC.
Currently, the diagnostic page shows the following-
How to solve this?
The MultipleNatFound in the error message is the issue, see this post for instance.
As you seem to have only one router, the problem is most likely your ISP running on IPv6.
However, Roon is currently working on / testing a solution for users with ISP that only have IPv6. If you feel comfortable, you can try this and hopefully get it working:
