Roon bridges are gone in audio section
There is no v3.5.3 image.
If you’re on v3.4.0 please install this hotfix that I have announced long time ago in the main rooExtend Support Thread.
After that, the nightly update will update your rooExtend to v3.5.3 :+1: :wink:
Best DrCWO
Thx, will do! :slight_smile:
At the moment 3.4.0 just works fine.
I can see it in the about section and I see the Roon bridge and after some hassle with my Genelecs music is also back.
Hmm, with my RPi3 in my bed room (connected via LAN) I do not get a continous streaming…
I have now always only a play time for a couple of seconds and than a way longer break of several seconds…
Even with a low quality 128 kps mp3 radio stream.
Not sure if this has anyting todo with rooExtend but with the old rooExtend version everything worked fine. :thinking:
(RPi4 works fine, RPi3 already underpowered?)
