Thanks for the feedback.
Iβll take a look.
Peter
Iβll take a look.
Peter
@peter_richardson
Trying out the fixed group feature.
Patrick
Thanks for testing everyone.
Seems only on creation a fixed group volume defaults to 100 - Iβll investigate. Shouldnβt effect any individual volumes.
See what you mean by βbouncing aroundβ - they settle but it looks odd so will explore.
Playing with db setting of AVR - do many people use this? Its a bit of a pain but interesting to explore.
Identified what I needed to change in default settings - a typo when I had changed the options for buffer size.
Will load a minor release this weekend - donβt think thereβs any real functionality impacted.
Keep the feedback coming.
Itβs actually working better than ever without the buffer set I am finding. Whether this is a side affect of extension and roon being on same machine now as I ditched using Rock I donβt know.
Hi All,
Iβve manually installed RHEOS on my Windows laptop and run it via Windows Powershell but Iβm getting the following βERROR LOADING CONFIG FILEβ issue.
When I run the app it briefly appears in the Roon Extensions section but crashes after a few seconds so I donβt get a chance to complete and save the settings.
Do you have any suggestions?
PS G:\ROON RHEOS\RHEOS-master> node .
23/02/2024, 01:14:55 STARTING ROON
192.168.50.21,Windows_NT,HP-DESKTOP-02G0VC7,win32,x64 Version : 0.8.6-0
βββββββββββ¬βββββββββββββββββ¬βββββββββββββ¬βββββββββββββββββββββ¬βββββββββββββββββββ¬βββββββββββββ¬ββββββββββ
β (index) β name β pid β model β ip β resolution β network β
βββββββββββΌβββββββββββββββββΌβββββββββββββΌβββββββββββββββββββββΌβββββββββββββββββββΌβββββββββββββΌββββββββββ€
β 0 β βHome Theaterβ β -744745573 β βDenon AVC-X3700Hβ β β192.168.50.246β β βCDβ β βwiredβ β
βββββββββββ΄βββββββββββββββββ΄βββββββββββββ΄βββββββββββββββββββββ΄βββββββββββββββββββ΄βββββββββββββ΄ββββββββββ
SUBSCRIBING Bedroom SONOS 2 1701aafa5b54f87dd7d8219823ea0c56d615
SUBSCRIBING Home Theater 170118b08a38a81d04ae096b3fa6af6df49c
SUBSCRIBING Creative AUX 1701b1831f6e4df939f72dcd48b8b4e4addd
SUBSCRIBING D10s 170128ffd8637a46016f947969e7da967adb
SUBSCRIBING WiiM 17019cf098ffc6404174692c0441ff98f09c
SUBSCRIBING Bathroom speaker 17016dd8ae312390d261bacb464697b93ead
SUBSCRIBING Living Room speaker 1701fc2e818ed52543b665d74b4e7ed56293
SUBSCRIBING Living Room Chromecast 1701d4763541eec3a30c940595f6ddc00398
SUBSCRIBING Bedroom Hifi Chromecast 17018691b69e06a9c13eb455a7dd07384c44
SUBSCRIBING Creative Katana V2 170129b86ffdf0cfdd2e9c14abe4e0e8597a
ERROR CREATING CONFIG XML Error: Command failed: ./UPnP/Bin/RHEOS2UPNP.exe -i ./UPnP/Profiles/config.xml -b 192.168.50.21
[01:14:55.701] main:1709 Starting squeeze2upnp version: v2.1.14 (Feb 24 2023 @ 16:40:44)
[01:14:55.701] main:1716
!!! ERROR LOADING CONFIG FILE !!!
[01:14:55.752] Start:1448 Binding to iface [WiFi]@192.168.50.21:49152 (http:0)
[01:14:55.885] AddMRDevice:1346 [01021EE0]: player has extended information
[01:14:56.033] AddMRDevice:1382 [01021EE0]: adding renderer (Bedroom Hifi) with mac BBBB-7099711C
at ChildProcess.exithandler (node:child_process:422:12)
at ChildProcess.emit (node:events:518:28)
at maybeClose (node:internal/child_process:1105:16)
at ChildProcess._handle.onexit (node:internal/child_process:305:5) {
code: 3221226505,
killed: false,
signal: null,
cmd: β./UPnP/Bin/RHEOS2UPNP.exe -i ./UPnP/Profiles/config.xml -b 192.168.50.21β,
stdout: ββ,
stderr: β[01:14:55.701] main:1709 Starting squeeze2upnp version: v2.1.14 (Feb 24 2023 @ 16:40:44)\r\nβ +
β[01:14:55.701] main:1716 \r\nβ +
β\r\nβ +
β!!! ERROR LOADING CONFIG FILE !!!\r\nβ +
β\r\nβ +
β[01:14:55.752] Start:1448 Binding to iface [WiFi]@192.168.50.21:49152 (http:0)\r\nβ +
β[01:14:55.885] AddMRDevice:1346 [01021EE0]: player has extended information\r\nβ +
β[01:14:56.033] AddMRDevice:1382 [01021EE0]: adding renderer (Bedroom Hifi) with mac BBBB-7099711C\r\nβ
node:internal/process/promises:289
triggerUncaughtException(err, true /* fromPromise */);
[Error: ENOENT: no such file or directory, open βG:\ROON RHEOS\RHEOS-master\UPnP\Profiles\config.xmlβ] {
errno: -4058,
code: βENOENTβ,
syscall: βopenβ,
path: βG:\ROON RHEOS\RHEOS-master\UPnP\Profiles\config.xmlβ
Node.js v20.11.1
I recently started having problems with no available speakers. Look at rooon shows that the squeezebox search is not finding any speakers. Using airplay or the HEOS app works fine. Also, the RHEOS app is not showing under extensions. Iβve restarted, uninstalled and reinstalled, but nothing. The install seems to go fine but RHEOS doesnβt display. Iβm also not running any sort of LM server and never have. Iβm guessing the squeezebox failure is at the heart of the problems, but not clear on what squeezebox requires to function.
For a little background, Iβve recently reorganized my network a bit by moving the static IP assignments from the devices to the DHCP and blocking some IOT devices. The HEOS devices have not had any blocks applied. I also updated DNS to force all devices to use pfsense for DNS.
Any thoughts about what I may have done to break squeezebox on roon?
Could you share your log file please.
It sounds like the changes may be affecting the ability of RHEOS to discover UPnP players moving from Static to DHCP may be the issue (Ive messed up things this way in the past β¦). You may want to try powering down your network completely and restarting. Then restart your ROON server and finally restart the device your run RHEOS on.
Is ROON Extension manager showing in the device extensions?
Sorry for the late response.
Can you look in the the directory you used to install (RHEOS)?
/UPnP/Profiles and see if there is a file config.xml
Are you able to open this? Could you share the content please (you may want to pm me as this will contain ip addresses). If there is no file - create on called config.xml (it can be empty)
Not many folks seem to use the windows version and I donβt usually test on a windows machine - so I may need to better look at whats happening for you.
Thanks Peter!
Just FYI, Iβve using static IPs previously. The change is moving the management of them to the DHCP service. Iβve powered everything up and down, restarted, reinstalled both App server (in deitpi) and RHEOS (in Roon). Iβve also repeatedly shut down and restarted ROON.
Rheos log
2024-02-23T03:18:12.122641000Z STARTING ROON CONNECTIONS
2024-02-23T03:18:12.168198000Z 2/23/2024, 3:18:12 AM STARTING ROON
2024-02-23T03:18:12.225027000Z INITIATING SERVICES
2024-02-23T03:18:12.226329000Z 192.168.1.4,Linux,DietPi,linux,arm64 Version : 0.8.6-0
2024-02-23T03:18:12.235004000Z STARTING HEOS CONNECTIONS
2024-02-23T03:18:12.236572000Z STARTING HEOS
2024-02-23T03:18:12.296943000Z
2024-02-23T03:18:52.200580000Z β Please ensure RHEOS is enabled in Settings -> Extensions
2024-02-23T03:19:02.202189000Z β Please ensure RHEOS is enabled in Settings -> Extensions
2024-02-23T03:19:12.204091000Z β Please ensure RHEOS is enabled in Settings -> Extensions
I canβt post the extension manager log as it is too large
Thanks, the logs are very helpful. Your devices are being discovered as expected. However the app is not being recognized - have you looked in the Extensions - > view authorizations to see if the extension is showing up there? You should only have one showing - if there are multiple delete and re -enable.
If this doesnβt work it may be that the address changes have impacted the ability for ROON to connect with the extension. I would try re booting the ROON server and if that doesnβt work power down and restart the server.
Hope this works. Nothing has changed in the code for the past couple of weeks. (Though I am working on improving discovery at present to address the request to be able to enable new HEOS players without having to restart (way more challenging than I had thought β¦)
Yes creating a blank config.xlm file solved it, thanks ever so much for your help! ![]()
Its something about windows and file permissions I think.
Enjoy!
The issue turned out to be Tailscale. I use Tailscale to provide secure remote access to my network (including Roon ARC) and it works great. Unfortunately, the tailscale client canβt be running on the same box as Roon server. I knew this from when I first installed Tailscale and then forgot while refiguring my network that I had reinstalled it on the windows box that runs Roon server. So stupidβ¦but removed it and RHEOS is running great! Sorry for the time wasterβ¦
I have Tailscale running, extension manager with Rheos and roon server on same machine I donβt have any issues like you.
Always interesting to explore these things.
Thanks so much for sharing this! I figured that it was just a configuration issue on my part, so Iβll come back around and try it again. It is, however, easy enough to add the 192 network as a subnet to tailscale on my firewall, so ARC still works without it. Iβll post any findings when I try againβ¦
NEW TEST VERSION AVAILABLE
version 0.9.0-0 has been uploaded to GitHub and to the TEST Docker image.
This addresses the need to be able to update players βon-the-flyβ and required re-coding of the whole configuration process.
This results in significant improvements in speed of loading and creation of players. In addition, if a HEOS device is disconnected or reconnected the device is created and added without stopping all other players.
HEOS devices usually notify when added or disconnected and will be automatically added or deleted but, in addition, I have added the ability to check manually for new devices and add/remove them if they are no longer discovered. It can take a minute or so after connecting for them to be available and a couple of minutes after they have been disconnected before they will be removed.
This also removes the creation of a UPnP config file which has been causing some issues on windows systems.
There is no longer 30 seconds of searching for players as once a HEOS device is connected it finds other players instantly. To do this please make sure that their firmware is updated.
In addition several other small bugs have been addressed.
PLEASE TEST AND GIVE ME FEEDBACK. I suggest you save a copy of the old version you are using if installing from NPM/GitHub so you can revert if there are issues. I am not updating the βLatestβ docker image until we check on any unforeseen issues.
awesome @peter_richardson β I will download and test nowβ¦
Wow, the search and add runs REALLY FAST! next up thru the day, unplug and replug denon and heos speakers ![]()
