Roon Extension : RHEOS 2-way control & 192Hz/24bit Playback and Grouping on Denon/Marantz HEOS devices now in Extension Manager
Reverted image back to 0.8.6-0 which was stable.
I’d appreciate folks helping me test 0.9.1-x further as there are several features which improve performance for me and address recent request - but clearly it needs more testing!
Peter
.9.1.1 seemed ok to me, its only after that this all started
I’m just wondering if there is an unanticipated clash between the two. Something very odd. I have 0.8.6-0 running as expected on my raspberry pi.
Wont work on 0.8.6 either for me
Then its something on your end that’s changed and haven’t spotted. As you know this version was very stable. Any other changes? Share the 0.8.6-0 log if you can as we need to look for clues…
It doesnt crash it, its just doesnt play same as before sticks on 0:00 I have nothings changed other than standard debian apt updates.
Got it to work by restarting the extension again.
Good. Obviously not sure whats going on. Ill keep 0.8.6-0 there as the latest and continue testing 0.9.1-4 as thoroughly as I can hopefully with input from others.
I dont see any more errors in the log either.
Kent
You’ll see I reverted back to 0.8.6-0. I will be interested to see how that works for you and if it fixes your problem too.
@Simon_Arnold3 , @peter_richardson - I get this every once in a while usually after updating roon or rheos or any other extension like rooDial or macroon (I do not use extension manager) β€” this is where the track sticks at zero seconds and will not play… recycling usually does it BUT sometimes its that HEOS has a different understanding of what speakers are grouped and what are not grouped vs roon/rheos (not always, i think, i will watch for it more going forward)
for me, when it stops β€œplaying” and stuck at zero seconds - I do a few things when i cannot get it working:
stop rheos
stop roon
in heos, group and ungroup speakers and play to get heos back to normal (and not in lms mode)
start up roon
start up rheos
get back to awesome listening features and remember, its a first world problem… :slight_smile: ha
again, this is RARE and this is not specific to versions…
I think HEOS gets confused and is not in a proper state for either roon or rheos and neither side β€œknows it”
i dont have any groups, I have only one HEOS zone my amp, its never done this prior to recent updates. But I do find volume issues tend to happen after an update.
Thanks Patrick.
You’re using the test docker image correct?
Could you see what happens with 0.9.1-4 the latest. Its working well for me and as you know allows the refresh of players, faster loading and fixes the bi directional control which I had regressed (an I think would be useful for folks). However I don’t want this to cause crashes that can be frustrating.
Let me know how it goes for you and I am going to check additional platforms.
Peter
Volume issues are likely when the app has exited without shutting down the virtual squeezeplayers. When exited normally this is done and on restart it also refreshes these.
Its possible that if other programs create virtual squeezeplayers these could interfere. Its not been an issue to date but I would value any reports of this.
Will test it tonight when I am back at home… (since figuring out how to get the config file to persist between image updates, everything goes pretty swimmingly [if i didnt just jinx that] and I dont need to disable/enable the extension, just cycle the image and force download of the latest image in portainer…
@Simon_Arnold3 - I stopped using zones because denon had a refirb sales on s660h and you could stack discount codes - got one for $144 ish before tax etc - crazy…
@peter_richardson is the volume bumping around issue fixed with saved groups in this release, I will test that too over the weekend if so…
PS - yes, I run both your rheos and roon as docker images on Synology NAS and isolated to an β€˜entertainment’ macvlan only (also the rooExtend roodial and the macroon macro tool too, plex and minimserver all on this macvlan) -
Still bounce a little … on the list to improve but works for me…
I’m starting to feel like a complete idiot, but let’s walk through this…
DONE (and I didn’t know this requirement) – Make sure all receivers are switch on and both zones are switched on as well.
DONE – Go to Settings β†’ Extensions β†’ View and Remove all RHEOS authorizations.
DONE – From extension manager Stop RHEOS and remove then reinstall. Version should be 0.9.1-4 (Don’t forget to save after each step or it wont take effect)
DONE – Then Start RHEOS.
DONE – Go to Settings β†’ Extensions β†’ View and Enable RHEOS. Only one version should be running.
Go to the RHEOS extension settings.
DONE – Check Enable AVR zone control is ON (if it isn’t select and save).
Nothing below is working and no zone 2 devices show in the queezebox area…
Go to Settings β†’ Audio β†’ Squeezebox and make sure there is a player for the Receiver itself and Main Zone and Zone 2 (Main Zone and Zone 2 are only created when the Zone is turned on on the receiver). and they are enabled
Then go back to device setup for the AVR (not Main or Zone 2). Clear any previously attached source and volume controls by selecting β€œLoad Defaults” from the top corner.
You should then be able to attach the appropriately named Main Zone, Zone 2 and Source control and Volume control for the AVR by Add external source control or volume control.
Save.
2024-03-08T19:05:41.245229000Z STARTING ROON CONNECTIONS
2024-03-08T19:05:41.289648000Z 3/8/2024, 7:05:41 PM STARTING ROON
2024-03-08T19:05:41.335741000Z INITIATING SERVICES
2024-03-08T19:05:41.336981000Z 192.168.1.4,Linux,DietPi,linux,arm64 Version : 0.8.6-0
2024-03-08T19:05:41.346438000Z STARTING HEOS CONNECTIONS
2024-03-08T19:05:41.347820000Z STARTING HEOS
2024-03-08T19:05:41.599294000Z β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
2024-03-08T19:05:41.600825000Z β”‚ (index) β”‚          name           β”‚     pid     β”‚        model        β”‚       ip        β”‚ resolution β”‚ network β”‚
2024-03-08T19:05:41.601171000Z β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
2024-03-08T19:05:41.601431000Z β”‚    0    β”‚      'Living room'      β”‚  945182341  β”‚  'Denon Home 350'   β”‚ '192.168.1.185' β”‚    'HR'    β”‚ 'wired' β”‚
2024-03-08T19:05:41.601661000Z β”‚    1    β”‚      'Garage HEOS'      β”‚  517302361  β”‚  'Denon DRA-800H'   β”‚ '192.168.1.245' β”‚    'HR'    β”‚ 'wired' β”‚
2024-03-08T19:05:41.601900000Z β”‚    2    β”‚   'Home Theater HEOS'   β”‚ 1176195927  β”‚ 'Denon AVR-X3700H'  β”‚ '192.168.1.249' β”‚    'HR'    β”‚ 'wired' β”‚
2024-03-08T19:05:41.602121000Z β”‚    3    β”‚      'Patio HEOS'       β”‚ 1238197077  β”‚ 'Denon AVR-X3600H'  β”‚ '192.168.1.118' β”‚    'HR'    β”‚ 'wired' β”‚
2024-03-08T19:05:41.602344000Z β”‚    4    β”‚   'Kitchen MODEL 40n'   β”‚ -1378453859 β”‚ 'Marantz MODEL 40n' β”‚ '192.168.1.211' β”‚    'HR'    β”‚ 'wired' β”‚
2024-03-08T19:05:41.602606000Z β”‚    5    β”‚    'Master Bedroom'     β”‚ 1172627996  β”‚  'Denon Home 350'   β”‚ '192.168.1.250' β”‚    'HR'    β”‚ 'wifi'  β”‚
2024-03-08T19:05:41.602837000Z β”‚    6    β”‚ 'Workout room soundbar' β”‚ -643584911  β”‚  'Denon DHT-S516H'  β”‚ '192.168.1.52'  β”‚    'HR'    β”‚ 'wifi'  β”‚
2024-03-08T19:05:41.603062000Z β”‚    7    β”‚ 'Family room soundbar'  β”‚  486241238  β”‚  'Denon DHT-S716H'  β”‚ '192.168.1.248' β”‚    'HR'    β”‚ 'wifi'  β”‚
2024-03-08T19:05:41.603284000Z β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
2024-03-08T19:05:41.613088000Z DISCOVERING DEVICES
2024-03-08T19:05:41.623481000Z READING PROFILES 8
2024-03-08T19:05:41.627253000Z 3/8/2024, 7:05:41 PM UPDATING CONFIG
2024-03-08T19:05:41.628293000Z 3/8/2024, 7:05:41 PM CREATING ROOT XML
2024-03-08T19:05:41.940872000Z 3/8/2024, 7:05:41 PM CREATING CONFIG FROM IP 192.168.1.4
2024-03-08T19:05:51.308846000Z  ⚠ Please ensure RHEOS is enabled in Settings -> Extensions
2024-03-08T19:06:01.309110000Z  ⚠ Please ensure RHEOS is enabled in Settings -> Extensions
2024-03-08T19:06:08.464915000Z DISCOVERING DEVICES
2024-03-08T19:06:08.467113000Z BUILDING DEVICES
2024-03-08T19:06:08.467547000Z BUILDING DEVICES
2024-03-08T19:06:08.563175000Z CREATING Garage HEOS
2024-03-08T19:06:08.584850000Z CREATING Master Bedroom
2024-03-08T19:06:08.604023000Z CREATING Home Theater HEOS
2024-03-08T19:06:08.625754000Z CREATING Kitchen MODEL 40n
2024-03-08T19:06:08.649017000Z CREATING Family room soundbar
2024-03-08T19:06:08.671426000Z CREATING Workout room soundbar
2024-03-08T19:06:08.690826000Z CREATING Patio HEOS
2024-03-08T19:06:08.722164000Z CREATING Living room
2024-03-08T19:06:08.778680000Z ROON SERVER IP ADDRESS undefined
2024-03-08T19:06:08.780074000Z CREATING ZONE CONTROLS
2024-03-08T19:06:08.780467000Z TESTING IF AVR Garage HEOS
2024-03-08T19:06:08.786654000Z TESTING IF AVR Home Theater HEOS
2024-03-08T19:06:08.787995000Z TESTING IF AVR Patio HEOS
2024-03-08T19:06:08.789385000Z TESTING IF AVR Workout room soundbar
2024-03-08T19:06:08.791678000Z TESTING IF AVR Family room soundbar
2024-03-08T19:06:08.792823000Z TESTING IF AVR Kitchen MODEL 40n
2024-03-08T19:06:08.798359000Z STARTING TO MONITOR AVRS
2024-03-08T19:06:08.798689000Z ADDING LISTENERS
2024-03-08T19:06:08.799722000Z SETTING LISTENERS
2024-03-08T19:06:08.801507000Z UPDATING HEOS GROUPS
2024-03-08T19:06:08.809906000Z CREATING FIXED GROUPS
2024-03-08T19:06:08.818206000Z SETTINGS [
2024-03-08T19:06:08.818518000Z   [ 'default_player_ip', '' ],
2024-03-08T19:06:08.818674000Z   [ 'host_ip', '' ],
2024-03-08T19:06:08.818804000Z   [ 'streambuf_size', 271440 ],
2024-03-08T19:06:08.818943000Z   [ 'output_size', 8388608 ],
2024-03-08T19:06:08.819085000Z   [ 'stream_length', -3 ],
2024-03-08T19:06:08.819224000Z   [ 'seek_after_pause', 0 ],
2024-03-08T19:06:08.819419000Z   [ 'volume_on_play', -1 ],
2024-03-08T19:06:08.819589000Z   [ 'volume_feedback', 0 ],
2024-03-08T19:06:08.819731000Z   [ 'accept_nexturi', 0 ],
2024-03-08T19:06:08.819883000Z   [ 'flac_header', 0 ],
2024-03-08T19:06:08.820042000Z   [ 'keep_alive', 0 ],
2024-03-08T19:06:08.820166000Z   [ 'next_delay', 15 ],
2024-03-08T19:06:08.820310000Z   [ 'send_coverart', 0 ],
2024-03-08T19:06:08.820435000Z   [ 'send_metadata', 0 ],
2024-03-08T19:06:08.820615000Z   [ 'flow', 0 ],
2024-03-08T19:06:08.820755000Z   [ 'max_safe_vol', 70 ],
2024-03-08T19:06:08.820889000Z   [ 'avr_control', 1 ],
2024-03-08T19:06:08.821024000Z   [ 'fixed_control', 1 ],
2024-03-08T19:06:08.821158000Z   [ 'log_limit', 100 ],
2024-03-08T19:06:08.821278000Z   [ 'clear_settings', 0 ],
2024-03-08T19:06:08.821394000Z   [ 'refresh_players', 0 ],
2024-03-08T19:06:08.821521000Z   [ 'upnp_ip', '192.168.1.3' ]
2024-03-08T19:06:08.821734000Z ]
2024-03-08T19:06:08.837104000Z FAMILY ROOM SOUNDBAR ZONE 2 NOT DETECTED
2024-03-08T19:06:08.839679000Z WORKOUT ROOM SOUNDBAR ZONE 2 NOT DETECTED
2024-03-08T19:06:10.810919000Z GARAGE HEOS HAS POWER SWITCH
2024-03-08T19:06:10.815425000Z PATIO HEOS HAS POWER SWITCH
2024-03-08T19:06:10.820405000Z KITCHEN MODEL 40N HAS POWER SWITCH
2024-03-08T19:06:10.825193000Z HOME THEATER HEOS HAS POWER SWITCH
2024-03-08T19:06:11.309250000Z  ⚠ Please ensure RHEOS is enabled in Settings -> Extensions
2024-03-08T19:06:12.835374000Z GARAGE HEOS HAS ZONE 2
2024-03-08T19:06:12.837753000Z CREATING AVR CONTROLS FOR Garage HEOS
2024-03-08T19:06:12.838462000Z CREATING VOLUME CONTROL Garage HEOS 517302361
2024-03-08T19:06:12.839996000Z CREATING SOUND MODE  Garage HEOS β™« Sound Mode
2024-03-08T19:06:12.844942000Z PATIO HEOS HAS ZONE 2
2024-03-08T19:06:12.845552000Z CREATING AVR CONTROLS FOR Patio HEOS
2024-03-08T19:06:12.846005000Z CREATING VOLUME CONTROL Patio HEOS 1238197077
2024-03-08T19:06:12.846454000Z CREATING SOUND MODE  Patio HEOS β™« Sound Mode
2024-03-08T19:06:12.850768000Z KITCHEN MODEL 40N ZONE 2 NOT DETECTED
2024-03-08T19:06:12.851365000Z HOME THEATER HEOS HAS ZONE 2
2024-03-08T19:06:12.851906000Z CREATING AVR CONTROLS FOR Home Theater HEOS
2024-03-08T19:06:12.852627000Z CREATING VOLUME CONTROL Home Theater HEOS 1176195927
2024-03-08T19:06:12.853108000Z CREATING SOUND MODE  Home Theater HEOS β™« Sound Mode
2024-03-08T19:06:14.861408000Z GARAGE HEOS SOUND MODE IS STEREO
2024-03-08T19:06:14.864045000Z PATIO HEOS SOUND MODE IS STEREO
2024-03-08T19:06:14.865907000Z HOME THEATER HEOS SOUND MODE IS STEREO
2024-03-08T19:06:21.309789000Z  ⚠ Please ensure RHEOS is enabled in Settings -> Extensions
2024-03-08T19:06:25.181671000Z 3/8/2024, 7:06:17 PM UNPAIRED
3/8/2024, 7:06:20 PM UNPAIRED
3/8/2024, 7:06:23 PM UNPAIRED
3/8/2024, 7:06:25 PM ROON PAIRED com.RHEOS.latest
2024-03-08T19:06:25.205704000Z SUBSCRIBING Girls Bathroom 17012d352f70bef4d4da94e9baf77cd18c6d
2024-03-08T19:06:25.208505000Z SUBSCRIBING Theater HEOS 17011e4b7ec3321495389cf0a23cb223c65b
2024-03-08T19:06:25.210844000Z SUBSCRIBING Patio HEOS 1701374390d7691506dccfba6b9a792f17f0
2024-03-08T19:06:25.214051000Z SUBSCRIBING Living room 170186d8788606cc429efbe434ab88638976
2024-03-08T19:06:25.218708000Z SUBSCRIBING Garage HEOS 1701fbef8c73b3af195dab10902315d22321
2024-03-08T19:06:25.220308000Z SUBSCRIBING Workout HEOS 17014a88d98f6f2fb0b574533efe979f2820
2024-03-08T19:06:25.222053000Z SUBSCRIBING kitchen marantz 170155beb08d21bdd92e02ac8dec300bc4cf
2024-03-08T19:06:25.223137000Z SUBSCRIBING Master Bedroom HEOS 17012d6a4d6db8978dc2c0228e37e7b268c8
2024-03-08T19:10:35.098024000Z 3/8/2024, 7:10:35 PM   🎡 Patio HEOS  β–Ά  I And Love And You - The Avett Brothers
I must be missing something - let me see what else II can suggest.
See if this video helps…
Really helpful!
Ideally starting with the AVR on and Heos playing from each zone can help (but isn’t essential).
First you are trying to add all the source controls to one of the AVRs.
Choose Garage AVR - then add source controls Garage Mani Zone and Garage Zone 2 only to that AVR.
Patio - do the same etc.
That should the allow you to go to the paler an click on the AVR β€œpower button” - this should then turn on the AVR if its off. There should be two additional controls for the Garage Main Zone and Garage Zone 2 - click on those and it should turn on the AVR zone and switch to HEOS (ROON) output. If you have not enabled in squeezebox they come up as unnamed and you need to edit the displayed name.
DO NOT try to do anything with the AIRPLAY zones.
