I don’t think that your problem is really the same or even related to what @Ayax_Conde has been posting about. Maybe have a look here (warning: long thread!):
@Andreas_Philipp1 thank you for this. I have not started the thread yet but just from the small description you linked to you are correct it does seem to describe my situation more precisely. Thanks for the link. I had not found this bothersome enough to actually go searching through the forums but am heading there now.
Hello @Ayax_Conde,
Roon uses OpenGL to display the user interface, and this implementation is essentially the same as a video game. If you try to temporarily set up a fresh database and only have a small local library imported, do you still notice the same behavior?
- Create a Backup of your current database
- Exit out of Roon
- Navigate to your Roon Database Location
- Find the folder that says “Roon”
- Rename the “Roon” folder to “Roon_old”
- Reinstall the Roon App from our Downloads Page to generate a new Roon folder
- Verify if the issue persists on a fresh database before restoring the backup
