I haven’t had much time listening lately and also just noticed it a couple of days ago I’m only guessing based on the other user.
Maybe it could be when I changed the name on mac mini to Matrix.
No, only used Roon’s backup option on Core and start fresh on remote’s.
Only the zones on iMac, Dragon Fly and ODAC USB headphone amp.
Yes all others, Sonos one, DigiOne and some Airplay shows.
Edit: After some thinking I did restore a iMac time machine on a Macbook to save time which might be the issue since now I’m listing on iMac and just open the lid on macbook and the music stopped on iMac, I uninstalled Roon on macbook and the zones shows again, I’m 99% sure the issue is solved I will post back if it’s not the case, thanks for your support and quickly getting back.
Yes, Time Machine has caused similar issues in the past as mentioned in our Backup documentation, so reinstalling was the right call here. Do let me know if the issue appears to be resolved!
