I’m using an iMac running Ventura 13.4.1 (c), Roon version 2.0 (build 1299). Can supply more detail if needed.
Roon hangs after a few hours, again and again. Need to Force Quit and restart it. Then repeat.
A few months ago I read a discussion thread here that seemed to suggest that this has happened to others. As far as I could tell, no solution (short of becoming a Roon engineer) was given then.
I’m now back because this problem continues. Has anyone figured out what one needs to do to fix this?
Moved from Uncategorized to Support. It would be good if you could complete the questions that are shown when posting directly in Support. This would help a lot to understand what the problem could be in your setup. You can copy it from here to a new reply:
<!-- Include your operating system and machine info (Model, CPU, RAM) →
<!-- Write below this line →
<!-- Your network gear (model of routers/switches), if on WiFi/Ethernet, and if you are using a VPN–>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) →
<!–Tell us how large your music library is, eg. “30,000 tracks” →
<!–Write below this line–>
<!–Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! →
