For the last several days Roon Radio will not select songs from Qobuz as it used to and the queue screen says it is limited to my library, despite the Limit Roon Radio To Library toggle switch being set to the off position. I can selectively play tracks from both Qobuz and my library without problems, but Roon Radio is no longer reaching outside my library as it used to. I have tried toggling the Limit To Library switch from off to on and back to off as well as signing In and out of Qobuz, these apparently being solutions that worked for others.
I’m running Roon 1.6 build 401 64-bit on Windows 7 enterprise, output to PS Audio Perfectwave DAC with Bridge II, using an iPad as a controller. Screenshot below.
