Latest version of roon core 1.7 build 521 running on Linux mint 19.3
Fully wired Ethernet, roon core pc, and naim ndx2 connected to net gear switch gs108, in turn connected to router.
Naim ndx2 using roon raat
Roon radio will not play anything from qobuz. I play a single track from my own library, at the end of the track I get “unexpected error” and “roon radio will play only from your library” even though it is set to use any source. If I play a track from qobuz the same error happens. So basically I get one song only and then nothing more.
I have restarted roon server
I have logged out and back in again to qobuz
I have toggled the roon radio only uses local setting on and off
I have to switch the roon radio setting to use local only otherwise it doesn’t work.
My qobuz subscription is a new one, I am still in the trial period, does that make a difference?
