Version 2.0 (build 1148 and tried on build 1149)
Windows 11 Pro, i9 9900K 64gb ram
Wired Network, with VPN, but Roon is excluded from it
All other external audio devices work fine, such as a BlueSound Node 2i, an Apple TV and Marantz AVR.
The PC itself has a Fostex USB Audio HP-A4 DAC, as well as an HDMI connection thru Nvidia Card, none of which will play.
3,400 tracks with Tidal
I’ve been using Roon fine for the last 2 weeks, both to control my BlueSound Node 2i and my PC when working. I had set up the PC to use the System Output so not to take full control of the audio device, as well as in WASAPI mode, if I wanted it to switch to HIRES.
I doubt it’s related, but the coincidence is strange, but my Trial expired on Friday and so I purchased a 1 year membership. This morning, when trying to get it to work on my PC, it simply refuses to play anything, simply skipping everything, with no message error. I’ve tried all Audio devices on the PC and all behave the same. Even installed ASIO drivers for the Fostex sound card, but this made no difference.
I was running an Early release version of it, so I did uninstall it to see if this would help. I didn’t, so I uninstalled again, this time deleting all preferences. It worked, for a few songs. Had to stop it for a an hour, refuses to play again since then.
The strange thing is, if I try to play to the Fostex set in exclusive mode, it does stop any other software from accessing it, so it does take control of it.
The only thing that changed this weekend, was that I installed the Android Virtual Machine now available on Windows 11, but I did also uninstall it…
Any help would be greatly appreciated!
