I was reading a thread yesterday about the new Titan and a couple of issues that @Dan_Sullivan was having with his new unit. I cannot find the thread today, has it been moved?
I was looking at purchasing a Titan, so was obviously a little disappointed to hear of the issues and wanted to see if there had been a solution. For someone like myself, with very little computer skills, it is important that a premium product works flawlessly and is well supported. Has the unit been replaced?
The problem was a bad cable. I chose to have Roon just send me a replacement cable because that is quicker than doing a Titan swap. They have overnighted it to me so I will have it tomorrow.
Hopefully that solves one issue for you. Have you had any resolution to the DSD issue?
I still canāt see the original thread on the forum, has it been deleted or hidden? It would be helpful if everyone that is interested can follow this to itās conclusion.
Having a faulty product is obviously not a good look, especially as itās a brand new premium product, so it would be good for any potential customerās confidence to know that Roonās customer service is following up and solving the problems. Anything less would suggest there is something to hide.
Iām just a little concerned about pulling the trigger on a purchase.
It was āunlistedā as it was not serving a public purpose anymore.
Like many support threads they tend to be diluted by opinions and occassionally a mash up of more than one issue.
And i think itās too early to say whether the poor processing was related to the broken cable.
Unlisted makes it feel more like itās been swept under the rug.
These posts usually get moved to the Feedback section. As I said before, it would suggest there is something to hide.
A bad side effect of doing support in public. The cable was broken and snapped off the connector. Itās the first one that was reported like this, out of hundreds of units shipped in the last month. We would have sent him a new unit, but he wanted the cable sent because itād be faster. He was overnighted the cable.
That said, you can see Danās post from last night showing that everything else is working fine, including the DSD:
Unlisted usually means we donāt want the public at large chiming in with help in cases where official support is on the case. Itās just added noise and often confuses the case.
If the cable is ripped off the connector, you can be pretty surethe issue of why the drive is not detected is the broken cable.
Sheesh guys, this is not rocket science and there are no conspiracies here.
This is a really good example of why the āprocessing speedā is bad UI.
The N100 CPU is so much less performant than the Nucleus Titan, yet it gives a higher processing speed. Itās because the N100 has a far worse power regulator, so itās just running faster at all times. The Titanās CPU is able to scale down as needed, so while itās probably capable of doing it at 100x+ at full power, that would waste electricity and generate unnecessary heat.
CPUs have become significantly more efficient since that UI was invented about 7-8 years ago, and they do so with power scaling which throws off the indicator. Funny thing is, the better your CPU, the lower your processing speed will be (but always decently above 1.0x).
Thereās often much noise and confusion on threads where official support has not (yet) been involved, too⦠but most of those support threads will not be unlisted and serve as reference for other usersā¦
Well. I also ordered the upgrade to Titan. After seeing the problems that Dan had I reached out to Roon sales with questions and concerns. Instead of helping me, they simply refunded the purchase price. Sort of sad. Donāt they care about selling product?
Not sure who you are asking, but if itās the community then nobody can make a useful comment as we donāt know anything about the conversation, and even if we did then we couldnāt comment on Roon Labās motivation.
Thatās tricky to answer. What does āno computer skillsā mean? To install a new drive or move an old drive, you need to be able to open the case, unplug the previous drive and resecure the loose cable in the old PC, close that case, open the new case, plug the new drive in and then close the case.
If it was a transfer of a drive from a previous ROCK/Nucleus then you need to just boot the new Nucleus up and it should be there. You probably will want to restore a database backup you made from the previous machine prior to starting the transfer. If it is a new drive, then you open up the Nucleus Web UI and format it.
To me, a techie, all the above is no computer skills needed, to my spouse, the attempt would have ended with āpick up a screwdriver to open the caseā.
Having physically moved drives in and out of Nuclues, it takes me mere minutes for the whole process. But, like I mentioned, Iām not a good baseline. I can build a ROCK NUC from unopened parts boxes to finished working server in less than 10 minutes.
Great post. Plus, with literally āno computer skillsā it would be pointless to use a Nucleus with an internal drive because the buyer would not be able to transfer music to it Most people who manage that will also manage to transfer a drive if they have instructions, unless there is a physical impairment.
