I just wanted to follow up and let you know that I spoke with the team and confirmed that they’ve reached out to Echo Audio. We haven’t heard back from Echo yet, but they should have the information needed for next steps here and you should be hearing from them soon.
You have our apologies for the prior miscommunication.
We spoke with Echo Audio about our next steps and I wanted to make sure we followed up with you here as well. We’re going to be replacing the Nucleus and you should be hearing more about this from Echo very soon.
In the meantime, I wanted to send over some instructions for backup up your database. You can back up Roon before you send out the Nucleus and then you can restore that backup once the new Nucleus is received. This will allow you to restore all of your Roon data onto the new Nucleus.
I have been working with Echo Audio. They verified the unit had the noise even with a couple of different supplies. Another unit they had in the store did the same thing. Yesterday they swapped me a replacement and it also has it. Is this a universal thing with these units? What does Intel say? It’s really not what I was expecting after springing for a fanless unit to have in my system.
Hi @rcaudio – First I’d like to express my sincere apologies for the ongoing issues here.
I just met with the team to discuss this. This isn’t an issue we are receiving widespread reports of, so we were very surprised to hear that this is happening for this Nucleus as well.
The last Nucleus that you had is currently on its way back to the manufacturer. They are going to be investigating the exact origin of this issue with us.
For now, we ask that you please hang on to the unit you have currently and use it as we investigate this. Once we have concluded our investigation into the previous Nucleus we will reach out to you with our next steps.
For our records, would you kindly confirm the serial number of the new Nucleus you’ve received?
Once again you have our sincere apologies here, Richard. I’ll be sure to keep you updated as our investigation procedes and will update you as soon as possible.
Thanks, @rcaudio — I’ve passed the serial number along to the team. I’ll be sure to reach out again when we have more information from our investigation.
Your patience and cooperation is very much appreciated!
