Sound issue with Samsung soundbar via Airplay and Roon update error (ref#2S70CT)
Full form submission
· I'm having trouble playing music
· Playback starts, but I don't hear any music
no sound when connected to my Samsung soundbar via airplay also Roon will not update, says error downloading update
Have you downloaded the newest version of Roon from Roon’s download site and tried to manually install it? Also, regarding your AirPlay issue, you may be experiencing a current issue with AirPlay behavior noted here
You may be able get Roon working with AirPlay if you move the progress bar a bit into the track, and then you can restart the track and everything should work as normal.
Has this ever worked for you? Because most people with that issue never had this working (there is no support for AirPlay 2 in Roon).
Hi @spayne20,
If you’re using a Samsung Q- or S-series soundbar, then you’ll require Airplay 2.0.
Airplay 2.0 compatibility is a commonly requested feature in Roon, but it’s not released at this time.
