In reference to the email I received -Re:[## 51895 ##] Roon Web Cancel Form (df5d4a43-1f9b-4423-bcfb-0747ace3054c)
I was enquiring about two issues on having with room.
Firstly the sound he is dropping out. Regularly for a second, over the wifi.
Secondly and when you start the application. Covering a home network, the naim mu-os qb mk1 starts at hundred percent.
Is your Core connected via WiFi or just the endpoint? Is this happening for all endpoints?
Are you referring to the volume level of the Naim device jumping to 100%?
My two week trial has ended now. I think I remember all the end points failing at some point. Even when directly broadcasting to the room ready mu-so mk 2.
