As a follow up to another thread in order not to highjack the OP’s thread I have posted a new issue and posted my setup details @mike as requested.
Describe Your Setup:
Build 128, v1.2 Linux 64
Unraid 6.1.9 via debian docker
Intel Xeon Unraid Server.
Local disks via data on the UnRaid Server.
Describe The Issue
Streaming to a Squeezebox Boom and Squeezebox Radio, either separately or both
in the same group, when streaming Tidal I get stuttering and eventual silence until I restart the core.
The Tidal tracks are set as 44.1k flac stream and not mp3.
Describe your Tidal Setup:
UK account.
Hifi (lossless) account
I don’t recall the track I was playing as it happened more than once.
I should add that if I add both SB Radio and SB Boom to a group and try and stream Tidal to them, the stuttering is immediate, but I am not sure if that is a supported config, so may not be expected to work correctly.
By way of an update, the latest version of 1.2 causes playback to stop on one of the group and continues playing on the other, while a few minutes after they swap and one stops and the other continues playing.
I have the same? problem and have some additional data that might help. When connecting a SB Boom player to Roon I get a very stuttered playback. At first I though this was a bandwidth issue as I have a low bandwidth connection between the RoonServer and the SB Boom (Home server to mountain cabin VPN link).
I then connected my Naim Mu-So over the same VPN Link and this device is playing just fine, hence this doesn’t seem to be a bandwidth issue but more a SB Boom issue. And by-the-way, I have SB Touch and SB Duet playing just fine in my home location (same subnet as server).
