Can’t seem to make USB audio work. Digital inputs are fine. Aries G2 or Aries Femto. USB works fine on both Streamers without Roon. Ideas?
Hello @mark_barry1,
Please provide a brief description of your current setup using this link as a guide.
Just to clarify things, what you’re saying is that you’re able to get the USB output from the ARIES G2 and ARIES Femto to pass audio when using the Lightning DS app for playback, but that when you use Roon to play to the ARIES Femto or ARIES G2 that the connected DACs do not receive the stream?
-John
Hi John- Yes, your correct. USB works fine using Lightning DS. Digital outputs works fine with both LDS and Aries.
Macbook Pro ( Sierra 10.12.6) Core
Aries G2 or Femto
Myteck Brooklyn or Mcintosh D100
Hello @mark_barry1,
I have enabled diagnostics on your account so our technical staff can get some more insight into what’s going on here. The next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers
The next time you attempt to play to the AURALiC devices in Roon using the USB outputs, please note the local time that you made the attempt. I can then request logs from your Roon Core for that time frame.
-John
