RoonServer is likely creating an entirely new Zone for the Parasound when it announces itself after losing sight of the mounted USB endpoint. Active DSP configurations on the affected Zone will influence this behavior - are you using any DSP with the Parasound when this occurs?
What happens if you refresh RAATServer entirely?
You can generate a new RAATServer instance on your device by following these instructions, but please be aware that this will reset your Roon Settings → Audio Tab to factory settings and I would advise making a backup of any custom DSP settings you have:
I can not find a way to generate a new RAATServer. There is no “factory settings” in settings/Audio tab.
Running the headless version of Roon server on Ubuntu 22.04, I also don’t know how to stop the service as I have it set to auto start… I am NOT a very experience Ubuntu user, I only installed it to support Roon 2
