Thanks for writing in and for your patience! Could you please reproduce the issue and share the specific date, time and name of the track playing when the issue occurs?
Once you let me know this info, I’ll go ahead and enable diagnostics for your account so I can review the logging for clues.
If you’d rather do it yourself manually, please use the directions found here and send over a set of logs to our File Uploader.
Hi! This happens all the time with every track. Tested now with Karen Elson - Green. 22.15 CET. I’m changing the volume slider or +/- in Roon, but the value just bounces back to what is pre-set in HQPlayer. Is that enough info?
Sure, running this now with the PowerMate puck disconnected and its SW off. No difference. Volume still bouncing back to whatever HQPlayer has it set to.
