Volume control stuck on fixed for HIFI Rose with Roon (ref#9F9OXA)
· my HIFI rose with roon is unable to change the device volume and is stuck in fixed volume. other devices work fine
I have tried a reboot and only stopped working last week , tried everything on the rose
· No vpn , Ethernet connection
I have the same with Denon Home 150. Does your device have a way to change the volume directly, like buttons on the device or a remote? Changing it on the device fixes it for me in Roon as well (until the next server restart).
I reported this new issue recently here in Early Access:
Hi @bill_ward,
Thank you for your post.
Please reboot RoonServer and then perform a cold reboot of the Hifi Rose endpoint: power it down, wait thirty seconds, and then power it up and allow for a device discovery cycle to conclude within Roon (wait for the Zone to reappear in Settings → Audio).
Please also try manipulating any physical volume control on the unit itself.
We’ll watch for your response. As @Suedkiez mentioned, there are now at least three devices with these reports, so our team is aware and investigating.
Hey, @bill_ward,
Just checking in on this. Were you able to reboot RoonServer, cold reboot the Hifi Rose endpoint, and wait for the Zone to show back up in Settings → Audio after discovery finished? Also, if you had a chance to try the physical volume control on the unit itself, let us know whether that changed anything. We are watching for your update, and our team is still investigating and it would be helpful to have the details from your end, thanks.
Hi
Yes all good . Saw a post that said power down the Rose and the nucleus then power up the Rose first. Wait for WiFi to connect then power up the nucleus. All good . Tried lots of ways and this before but in reverse order which didn’t work , the volume works from upheld iPad etc. been like this since last software update
Regards
Hi @bill_ward,
Glad to hear it is working now. The startup order you found, powering down the Rose and the Nucleus, then bringing the Rose up first, waiting for WiFi to connect, and then powering up the Nucleus, made the difference. It also sounds like the volume control works from the iPad, and that this has been happening since the last software update.
We will mark this thread for closure. Enjoy your music.
