Seen this issue before but doing it again for me. Pc running room controller Motorola android phone. As reported before . Doesn’t do it all the time but . Once it starts volume goes up automatically on its own to max
Thanks for the reply.
It’s a Motorola g82. 5g
Android 13 doesn’t seem to be available currently.
Phone system info says up to date
End points various but so far happend with Kef ls50ii wireless . And an Auralic Vega G2 (wired to network)
Still doing it . Phone now android 13
Currently doing it on ps audio direct stream dac with bridge ll
Help!!
Have you set volume limits for each device ? This should stop Roon going to full as a precaution. Its not a cure but will help until @support show up.
noris
September 28, 2023, 9:03pm
14
Conversation continued here:
Hey @AMT ,
Thanks so much for taking the time to write in, and my sincerest apologies for the sudden increase in volume! This is an issue we’re actively investigating.
If possible, are you able to share a timestamp (date, time) of when the issue occurred? With that, please use the directions found here and send over a set of logs to our File Uploader so we can take a closer look into what might be going on at the time of the volume spike.
In the meantime, we do have a short-term workaround tha…
