I use regular fixed internet
using Innuos Zen Mk3 connected to Esoteric N-05Xd
USB from Innuos to Esoteric player
mostly streams but has maybe 20 albums ripped from cd with the zen mini mk3
Volume runs to 100% like crazy, why? Just happens out of the blue, no hint, just suddenly it happens when I touch the digital control. I have set a limit in Roon so that the volume does not go further than 60% when it happened last time. Almost blew up the speakers.
Here is a link to a video that describes the problem: https://photos.app.goo.gl/3jmGKjqPfYR6uG2L8
I know this has been reported/posted before, just wanted to let you see the video of what is going on. Glad i have set a limit on volume in Roon. For the record, i am using Android app on both tablet and phone.
It’s pretty annoying. I’ve heard that if you disable Lock Screen controls on the Setup tab of Roon Settings on Android, the problem goes away…or at least is less frequent.
Hi @Oyvind_S,
Thank you for your patience while we worked through the queue. If you can provide the date, time, and track playing when the volume issue occurred we will activate diagnostics on your account and look into this further.
