Volume Too Low On Endpoints
I know this is old but I am now having the same issue and I can’t find where this was moved???
Hi John,
Are you looking for Volume Leveling? Right click or long press the Zone at the bottom right of the screen and select Zone Settings.
Cheers, Greg
After my server crashed, I had to reset my players. While I have volume leveling off, the volume is lower than it was and too low for one of my players even with volume at 100. I have it set for device volume.
Ideas?
Hi @John_Culver,
I have split your post from the previous topic so that we can better assist here. Can you please provide some more information regarding your setup using this thread as a guide?
Also, can you post a screenshot of your Signal Path for the zone that is experiencing this issue while there is music playing on it? The screenshot should look something like this:
Thanks,
Noris
