White noise occurs when using DSP/sample rate conversion
INTEL Core i3-8109U M.2 SSD
Roon rock
Ethernet, no VPN
Sonore Ultrarendu, Chord Dave, Mcintosh MA8900
Around 12,000 tracks
White noise happen when using DSP/sample rate set as max PCM rate.
It occurs when track file change from non-MQA to MQA(Tidal) files, and also from MQA to non-MQA files.
When stop DSP, this issue not occur.
Maybe setting resync delay fixes it…
If I remember I’ve seen talking about that. And maybe a solution
Chord user here.
Chord DACs don’t use off the shelf DAC chips.
ie: They do things differently.
Chord engineer/designer Rob Watts cautions against using 3rd party DSP and upsampling for his DACs (the switching noise you’re experiencing is a known consequence of this) and goes as far as to say they will sound better without such processing as they are already upsampling internally.
I’ve found this to be true
I forgot to include that using certain DSP with MQA is known to cause issues as well (on all DACs).
Have you tried disabling Roon’s MQA Core Decoder in the advanced tab of Device Settings?
I think if you disable that you cannot do DSP anymore. If I remember right. Roon needs that so to unfold the mqa, does DSP, them encapsulates back to mqa for the MQA ready dac
Ah.
That makes sense.
I thought DSP broke the MQA chain in some way which might be why OP only had issues with DSP + MQA.
Thanks, but did try this before but didin`t solve issue.
Yes, seems same. Thanks for sharing
As you say, seems Chord DAVE issue. I will stop using upsampling.
Normally yes except Roon can re-add the MQA signalling after applying DSP but only if Roon is handling core decoding. I believe Roon is the only player that can do this.
