Didn’t have the problem till now … the last build brought it in my case.
Yes, HD 4000 … and yes, i tried the intel drivers, and i tried the 32 bit version - problem still there
Sorry, but that’s not acceptable for a payed software. Nobody wouldnt accept if the car maker dont put a windshield wiper and say its not there problem, that its sometimes rainy.
Nobody can use a software blind and without UI, even is the best one in the galaxy.
Press the bottom left “Windows button” and search for “System Information”
Provide a screenshot of your System Information -> System Summary information
Provide a screenshot of your System Information -> Components -> Display information
Logs from your affected device immediately after the issue occurs. Logs can be accessed by using these instructions and sent through Dropbox / Google Drive / Send.firefox.com or alternate means.
I wanted to reach out and let you know that we released Roon 1.7 Build 610, which includes some improvements that we believe should help here. Please give the update a try and let us know if it helps!
