Android Roon Remote looses connection to Core (daily)
Hi @CRo,
Thanks for confirming the type of router you are using and for trying ROCK on the same machine.
Hmm, so everything works as expected when Roon is not communicating directly with the CentOS and you are still using the managed switch?
If so, that is most intriguing and would indicate that there is a setting on the CentOS itself which could be blocking this communication. I’m going to bring your findings to the team at our next weekly sync meeting and let them know this information, will let you know what they say. If the Ethernet adapter for your Android phone arrives, it would be interesting to note the behavior on the CentOS with and without a VM.
I wonder if there could be a 12 hour lease on some multicast functions imposed by linux itself. I have also found this article which may provide some more clues here since it seems that Hythim’s comment is very similar to the situation you are experiencing. Would any of his suggestion’s or the suggestions listed on that thread be applicable to your CentOS setup?
Thanks,
Noris
I’m also using CISCO SG300 series switches (IGMP snooping not active, multiple VLANs) and PfSense as router for my network. Wireless Access Points are CISCO WAP371. Core is running on a QNAP TBS-453a (Linux) behind a MikroTik hAPac configured as WLAN-bridge. Therefor, as far as the communication between Core and working as well as non working controllers go, they are all connected to the same AP and WLAN. Doesn’t this rule out the Router (PfSense) and Switches (CISCO SG300 series) from the equation?
Suffering from the endless “Searching for Roon Core” problem
  • Lenovo P2 (P2a42) phone running Android 7.0
  • Lenovo Yoga Tab3 Pro (YT3-X90F) tablet running Android 6.0.1
Connects fine every time I use it
  • Samsung Galaxy Tab S2 (SM-T810) running Android 7.0
If that’s the case, shouldn’t my SAMSUNG device not also be affected or do you talking about the Android Linux kernel?
Interestingly my Lenovo devices show up in Roon (on my PC) under Settings > Audio as long as the Roon app is running on them (showing the “Searching for Roon Core” message). If I activate and configure them from the PC, I can even play music on them. Looks like the Bridge part of Roon is working.
grafik
Hello @Noris,
I found the problem, and the solution. :smile:
tl;dr at the bottom of this post.
After looking at all that has been discussed here, and looking for commonalities in the test setups, I find the following points:
  • Roon core running natively on Linux (CentOS 7.6) looses connectivity to / is not reachable from Android Roon remotes / endpoints connected via Wifi, after some number of hours (far less than a day) of successful functioning. A restart of the Roon core (not the entire Linux OS) is required to get the Androids to function again.
  • Roon core running in a VM (ROCK, Windows 10) in a KVM VM on the same CentOS server communicates fine, with no failures with Android Roon remotes/endpoints connected via Wifi.
  • Roon uses multicast communication
  • IGMP snooping (on or off) on the switch does not change the outcome. A dumb vs. smart switch does not change the outcome.
I wanted to test another VM, running DietPi for example, but then I thought - it’ll probably work fine, again. I asked myself why I think that.
What’s the different between an application in a KVM VM running on Linux, and that application running natively on the machine hosting the KVM VMs?
  • The VMs and the host Linux system are using the same ethernet interface (NIC).
  • The NIC is shared with the VMs via a bridge (in the Linux OS)
So I looked at the bridge. A bridge passes along everything, it’s not a router. A bridge is like a switch in that sense. Does Linux mess with IGMP or anything in a bridge? No.
Any further differences?
  • The VMs (on the bridge) bypass the Linux firewall.
So I looked at the firewall rules.
My active firewall rules (stated in the very first post of this thread) conform to the Roon documentation. So, perhaps there is something that has as yet not been taken into account in the firewall documentation.
BINGO.
tl;dr:
It turns out Linux IPTables firewalls have to be explicitly configured to pass along IGMP.
The following is my (current) iptables configuration as pertains to Roon. In CentOS (and RHEL) this configuration is located in /etc/sysconfig/iptables :
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
## Defaults ##
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -i lo -j ACCEPT
## IGMP ##
-A INPUT -s 224.0.0.0/4 -j ACCEPT
-A INPUT -d 224.0.0.0/4 -j ACCEPT
-A INPUT -s 240.0.0.0/5 -j ACCEPT
-A INPUT -m pkttype --pkt-type multicast -j ACCEPT
-A INPUT -m pkttype --pkt-type broadcast -j ACCEPT
## Roon ##
# Core
-A INPUT -s 192.168.0.0/24 -p udp --dport 9003 -j ACCEPT
-A INPUT -s 192.168.0.0/24 -p tcp --match multiport --dports 9100:9200 -j ACCEPT
# Web Controller
-A INPUT -s 192.168.0.0/24 -p tcp --dport 8080 -j ACCEPT
The IGMP and Broadcast rules (in the ## IGMP ## block) are new (to my setup). The previously existing Roon rules (## Roon ##) are directly based on the Roon ports documentation.
Result: using Setup #1 (documented in this thread), and the addition of the IGMP rules added to IPtables on the CentOS Server, the Android Roon remotes/endpoints are able to function properly, even after the Roon core service on the CentOS Server has been running for many hours (a day) since last being restarted.
I have tested this for one day now on three Android phones of various models (also previously documented in this thread). In this time all three Android devices have previously al been unable to connect to the Roon core with Setup #1, before the addition of the IGMP iptables runles.
Further points for me to look at:
  • Longtime performance of the setup (we’ll see in a few more days / weeks if it holds up)
  • The Firewall is set to accept 224.0.0.0/4 - well, that’s a lot. I wish to test if a subset will work to not allow everything. This firewall ist NATed and firewalled separately to the internet (via pfsense), so fine, the entire world can’t com knocking anyway, but still, let’s see if this is necessary. :wink:
-Chris
@noris,
A status update: 48 hours since core restart and the Android endpoints / controllers are still connecting fine to the core.
-Chris
@Noris,
it’s been three days since the last Linux Roon core restart, and the Android remotes / endpoints are continuing to connect fine.
The Roon documentation currently does not treat IGMP and Broadcast as something that needs to be addressed in the local firewall configuration, only that it’s possibly an issue on the switch.
At this point, IGMP snooping is ON on my switch, and I don’t think it is relevant on or off. The point is that the Linux firewall natively blocks IGMP and broadcast (rightly so.)
I would suggest that perhaps you add to the Roon Linux documentation that the Roon core must be reachable not just via UDP 9003 and TCP 9100 - 9200 ports, but multicast and broadcast communication must also be allowed in the firewall.
Most Linux distributions use either iptables or firewalld (Red Hat Enterprise Linux and CentOS have iptables as default up to Version 6, as of RHEL 7 / CentOS 7 firewalld is started by default, iptables is also fully supported.)
iptables is the “classic” firewall daemon of Linux and IMHO much easier to configure if you haven’t wrapped your head around firewalld. I use iptables with CentOS 7. Hence here again, distilled down to the point, are the Linux iptables entries that are required for Roon to work properly:
## IGMP / Broadcast - required by Roon ##
## Roon ##
# Core
-A INPUT -s [Your Subnet]/[Subnet Mask] -p udp --dport 9003 -j ACCEPT
-A INPUT -s [Your Subnet]/[Subnet Mask] -p tcp --match multiport --dports 9100:9200 -j ACCEPT
[Your Subnet] would typically be for example 192.168.0.0 and [Subnet mask] is typically 24, ergo the UDP and TCP port entries would be for 192.168.0.0/24 .
Even if you don’t want to get into the details of how to enable the required ports because they are dependant on the user’s subnet, whatever that may be, the IGMP and broadcast entries are essentially universal; IGMP is not specific to any local network config, and can be documented for everyone.
If you want I can also make some firewalld entries, then just about every modern Linux distribution is covered. We could even cover IPv6 (but seriously, everything about Roon networking is based on the assumption of IPv4 networking, which is obviously the only sane thing to do at home.)
-Chris
Hello @CRo,
Thanks for the update, this was some very impressive sleuthing and I’m glad that we were able to get to the bottom of this issue!
I have a feeling that this thread will be helpful for others having similar issues, and the firewall settings you mentioned will be a great reference to have.
I discussed your findings with our technical team, and our QA team is going to look into these distinctions a bit more and update our documentation as needed.
Please keep me in the loop for any new updates you have to share and thanks again for your work on this thread, great job!
Thanks,
Noris
The Poirot of roon.
Thank you Noris and Ged_Hickman. =)
At work we have the network folks, and those are split off into the firewall folks, and then we have the Unix folks like me. And although I asked a network colleague about IGMP, and also talked to a firewall guy, that didn’t initially help much because these guys don’t mess with (wouldn’t stoop down to) OS-based firewalling; they work with Cisco Nexus switches and Juniper firewalls in an enterprise environment.
And I’m the Linux guy, and although I know the rudiments of networking (as the network folks make clear to me every time I deal with them), I rely on them to make the LAN and WAN and the DMZs work us.
So no, I didn’t have a clue that iptables blocks IGMP, and neither did my networking folks.
Now we know. :wink:
-Chris
Ah the UNIX guy in my day was the chap with the socks and sandals and the tooled leather holster for the mobile phone :peace_symbol:
